Log files not being correctly created
Continuing the discussion from Random Hangs of emonPi/emonSD:
Can someone with the newer SD Card running (I’m still on emonSD-17Oct19) check and see if their logs are being saved correctly by Log2Ram?
It might be an issue introduced with the latest Image.
@TrystanLea @glyn.hudson
Last updated a few months ago -
Seems OK to me.
@Vster Thanks for checking - please post as code between backticks ( 3 on a line before and 3 on a line after - ``` or the “Preformatted </>” format button) rather than images (especially if it gets large).
@rdavies6 - you might want to check as well.
We use a RAMLOG system so /var/log is mounted in RAM (to reduce SD Card wear).
pi@emonpi:~ $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       4.0G  2.6G  1.2G  68% /
devtmpfs        484M     0  484M   0% /dev
tmpfs           488M     0  488M   0% /dev/shm
tmpfs           488M   56M  433M  12% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           488M     0  488M   0% /sys/fs/cgroup
tmpfs           1.0M     0  1.0M   0% /var/lib/php/sessions
tmpfs           1.0M     0  1.0M   0% /var/tmp
tmpfs            30M     0   30M   0% /tmp
/dev/mmcblk0p1  253M   52M  202M  21% /boot
/dev/mmcblk0p3   10G  734M  8.8G   8% /var/opt/emoncms
log2ram          50M  6.6M   44M  14% /var/log
tmpfs            98M     0   98M   0% /run/user/1000
To preserver the logs, the /var/log folder is saved / restored at boot. logrotate rotates files into a separate folder /var/log.old.
It took me a while to remind myself, but log2ram is triggered hourly by cron (/etc/cron.hourly/log2ram). This same cron job triggers logrotate first.
journalctl -n 50 -u log2ram will tell you what is happening with log2ram.
As @rdavies6 says the rotated files are empty, there may be an issue with logrotate. To investigate you need to look at the logrotate.log file.
Here’s mine emonSD-24Jul20:
/dev/root       4.1G  2.7G  1.2G  70% /
devtmpfs        431M     0  431M   0% /dev
tmpfs           463M     0  463M   0% /dev/shm
tmpfs           463M   47M  417M  11% /run
tmpfs           463M     0  463M   0% /sys/fs/cgroup
/dev/mmcblk0p1  253M   54M  199M  22% /boot
/dev/mmcblk0p3  9.9G  1.6G  7.8G  17% /var/opt/emoncms
log2ram          50M  9.4M   41M  19% /var/log
tmpfs            93M     0   93M   0% /run/user/1000
pi@emonpi:~ $ journalctl -n 50 -u log2ram
-- Logs begin at Tue 2022-07-12 19:52:59 BST, end at Wed 2022-07-13 22:20:42 BST
Jul 13 19:17:03 emonpi log2ram[6000]: logrotate/logrotate.status
Jul 13 19:17:03 emonpi log2ram[6000]: sent 394,770 bytes  received 7,276 bytes
Jul 13 19:17:03 emonpi log2ram[6000]: total size is 6,620,785  speedup is 16.47
Jul 13 19:17:03 emonpi systemd[1]: Reloaded Log2Ram.
Jul 13 20:17:01 emonpi systemd[1]: Reloading Log2Ram.
Jul 13 20:17:01 emonpi log2ram[7202]: sending incremental file list
Jul 13 20:17:01 emonpi log2ram[7202]: auth.log
Jul 13 20:17:01 emonpi log2ram[7202]: daemon.log
Jul 13 20:17:01 emonpi log2ram[7202]: log2ram.log
Jul 13 20:17:01 emonpi log2ram[7202]: syslog
Jul 13 20:17:01 emonpi log2ram[7202]: emoncms/wificheck.log
Jul 13 20:17:01 emonpi log2ram[7202]: emonhub/emonhub.log
Jul 13 20:17:01 emonpi log2ram[7202]: logrotate/
Jul 13 20:17:01 emonpi log2ram[7202]: logrotate/logrotate.log
Jul 13 20:17:01 emonpi log2ram[7202]: logrotate/logrotate.status
Jul 13 20:17:01 emonpi log2ram[7202]: sent 3,063,920 bytes  received 6,010 bytes
Jul 13 20:17:01 emonpi log2ram[7202]: total size is 9,674,653  speedup is 3.15
Jul 13 20:17:01 emonpi systemd[1]: Reloaded Log2Ram.
Jul 13 21:17:02 emonpi systemd[1]: Reloading Log2Ram.
Jul 13 21:17:02 emonpi log2ram[8417]: sending incremental file list
Jul 13 21:17:02 emonpi log2ram[8417]: ./
Jul 13 21:17:02 emonpi log2ram[8417]: auth.log
There’s about 1.8MB in rotated logs
@borpin Sorry my bad.
@TrystanLea yes, everything looks fine on my Pi too, including big(!) compressed files for the emonhub.1.gz in the /var/log.old/emonhub/ folder. Gunziping the emonhub.log.X.gz files has valid emonhub type logging in it.
Ha, no bother. It is one of those things that can easily slip through and not be noticed until you need the logs!
