The problem i have now is that the legend of the graph looks different in graph module than in dashboard.
Also, the label for each item used may look/built diffently:
In Dashboard:
Node:0:node.0.loadwatts versus Gusi:Node:0:soc
In Graph:
Sometimes labelled “undefined” (here i should read “Batteryvolts”)
Most annoying is when a legend contains “undefined” although the field has a name. And the field labelled as undefined changes. Its not always the same field.
This way it will display the correct feed name, it is only when selecting a feed by the right hand checkbox first that this occurs. It has been reported as a bug.
Your previous bug where the tags are always shown on dashboard embedded graphs,even when disabled from the graph editor page, is also known and we hope @TrystanLea might return to solve these bugs at sometime in the future
