Does the error go when you select ‘graphs’ or does it persist? Try changing something on the graphs, add a feed and then delete it and so you can save the graph.
Your data sources should just appear in the Inputs page. Does it?
The error persists, each time you re-select the “Graphs” menu at the left.
In my inputs page, I had 3 things listed, all called “emo”, as if it was truncated. It looks like one of them is the emonpi, the other two are emonth sensors. I can select them to initialise them, but can’t see any data. As it stands, I should have 2x wired dallas sensors, 2x TH RF sensors, AC mains sensor, current clamp, etc.
The graphs are all in an “undefined” submenu, and where it has created new graphs for the emonpi (by initialising it), the drop-down to select a graph (under MyGraphs) is completely empty.
Can you do a screen shot of what you currently see? Win 10 you can just Win+shift+S, Alt+PrtScrn, or use the snipping tool, then just paste it in a message.
pi@emonpi:/var/www/emoncms $ ls -la /var/www/emoncms/
total 216
drwxr-xr-x 9 pi pi 4096 Oct 19 15:15 .
drwxr-xr-x 4 pi root 4096 Aug 15 2018 …
-rw-r–r-- 1 pi pi 513 Oct 19 12:26 composer.json
-rw-r–r-- 1 pi pi 1025 Oct 19 12:26 COPYRIGHT.txt
-rw-r–r-- 1 pi pi 8052 Oct 19 12:26 core.php
-rw-r–r-- 1 pi pi 7037 Oct 19 12:26 default.emonpi.settings.php
-rw-r–r-- 1 pi pi 5843 Oct 19 12:26 default-settings.ini
-rw-r–r-- 1 pi pi 7130 Oct 19 12:26 default-settings.php
drwxr-xr-x 4 pi pi 4096 Oct 19 12:26 docs
-rw-r–r-- 1 pi pi 2063 Oct 19 12:26 example.settings.ini
drwxrwxrwx 8 pi pi 4096 Oct 19 13:38 .git
-rw-r–r-- 1 pi pi 413 Oct 19 12:26 .gitignore
-rw-r–r-- 1 pi pi 8917 Oct 19 12:26 .htaccess
-rw-r–r-- 1 pi pi 16213 Oct 19 12:26 index.php
-rw-r–r-- 1 pi pi 223 Aug 2 2018 .jshintrc
drwxr-xr-x 11 pi pi 4096 Oct 19 12:26 Lib
-rw-r–r-- 1 pi pi 32386 Aug 2 2018 LICENSE.txt
-rw-r–r-- 1 pi pi 3703 Oct 19 12:26 locale.php
drwxr-xr-x 17 pi pi 4096 Oct 19 12:27 Modules
-rw-r–r-- 1 pi pi 4119 Aug 2 2018 param.php
-rwxr-xr-x 1 pi pi 95 Aug 2 2018 php-info.php
-rw-r–r-- 1 pi pi 4585 Oct 19 12:26 process_settings.php
-rw-r–r-- 1 pi pi 12504 Oct 19 12:26 readme.md
-rw-r–r-- 1 pi pi 4821 Oct 19 12:26 route.php
drwxr-xr-x 6 pi pi 4096 Oct 19 12:26 scripts
-rw-r–r-- 1 pi pi 628 Oct 19 12:26 settings.env.ini
-rw-r–r-- 1 pi pi 7037 Oct 19 12:26 settings.php
drwxr-xr-x 4 pi pi 4096 Oct 25 2018 tests
drwxr-xr-x 3 pi pi 4096 Aug 2 2018 Theme
-rw-r–r-- 1 pi pi 111 Oct 19 12:26 .travis.yml
-rw-r–r-- 1 pi pi 7 Oct 19 12:26 version.txt
Ok so I’m not sure why the inputs and feeds have not been created properly.
Just so I’m clear, you started with the
Not the 2019 image?
On the admin page, next to the server infomation header there is a button ‘copy as markdown’. Could you do that and post it here please?
The lack of MQTT will explain no data.
Try
systemctl status mosquitto.service
sudo systemctl restart mosquitto.service
and post the output please.
When posting code or console output, please put 3 backticks (top left of keyboard) ```on a line before and 3 more on a line after - no other formatting.
See attached. I think the last 6 nodes were added since migration by trying to set up inputs (the last feed I had in the old config was [[7]] nodename = emonTx_4
Just checking which config I should be looking at… the extracts above are from emonhub.conf from the web interface, but if I go to /home/pi/emonhub/conf/emonhub.conf then the contents are different:
