emonSD Download — OpenEnergyMonitor 0.0.1 documentation lists the latest version as emonSD-01Feb24, while EmonScripts/safe-update at master · openenergymonitor/EmonScripts · GitHub says there is two newer versions. specifically I would like to update to emonSD-10Mar26 since it was just released. I am mostly looking to update as home assistent is complaining that I need a newer version of emonCMS with a message “Your emoncms does not ship a unique identifier. Please upgrade to at least version 11.5.7 and migrate your emoncms database.” updating the system does not need any DB schema changes.
Those newer version of emonSD are not avilable yet. But you can update Emoncms by running a Admin > Update > Full Update
I am running an older image than the latest. I will try the latest. I have fully updated the image I have. I, however, still get the prompt in Home Assistant to update EmonCMS.
What version of Emoncms are you running? 11.6.9 minimum is required for HA integration.
Running Emoncms update should update to latest 11.10.2. The Emoncms version is separate to emonSD version.
