Is it possible to add a last updated label on the dashboard? if so how is it done?
Have you tried the feedtime widget?
Paul
i only see a feedvalue
Have you updated your dashboard installation?
What version of dashboard are you using (Or are you using emoncms.org?)
Paul
correct on that one ![]()
The feedtime widget has been in the dashboard master branch for a few months now, but I don’t know if @TrystanLea plans to, or is able to merge it into emoncms.org.
It’s certainly a useful widget.
Paul
it sure is/would be
@TrystanLea please add it if you can without smoke escapes from the servers
[Post moved here from Emoncms.org slow?]
thanks @TrystanLea
any plans for adding the feedtime widget to emoncms.org?
[ Post moved here from Feedtime widget to emoncms.org?]
any plans for adding the feedtime widget to emoncms.org ?
@Boelle please try not to ask the same question multiple times in multiple places. G&T are just as likely to see all your posts equally. They are not able to respond to all @mentions, asking the question more often is very unlikely to speed up or improve the odds of getting a reply, possibly the opposite.
