Hi Everyone.
I have had an emonpi for nearly 2 years but I am just realising something happened a few months ago and there is now a significant difference between the kWh calculated from the power input and the kWh from the pulse count.
It looks like it started back in April (I don’t pay enough attention to it but I think I had an issue with it not collecting for a bit and I ended up doing an update on it).
This is the 2 feeds for it, scaled by 0.001 and as you can see after April, the 2 feeds are diverging.
As bars for the daily usage, this is a little more obvious:
It is possible that the calculated value is correct and my energy usage went up, rather than that being the one that is wrong. Looking at the first line chart, I would make the assumption that that is the case rather than reducing like the pulse would suggest.
I followed this guide when setting up and have just checked it through again:
Oddly though, I have to use the scaling factor of 0.001, rather than 1 like the guide says, to get anything close to sensible figures.
My meter says it is 1000 pulses per 1kWh
This is the pulse input setup:
I have just upgraded again yesterday so not sure what versions I have been on, but this is the details now:
emonpiRelease: emonSD-26Oct17
Version
low-write 10.1.6
Modules
Administration | App v2.0.6 | Backup v2.1.2 | EmonHub Config v2.0.4 | Dashboard v2.0.4 | Device v2.0.1 | EventProcesses | Feed | Graph v2.0.4 | Input | Postprocess v2.1.0 | CoreProcess | Schedule | Network Setup v1.0.0 | sync | Time | User | Visualisation | WiFi v2.0.1
I am contemplating swapping to the latest emonpi release as the logs are not working after my upgrade yesterday but need to get another SD card and spend some time on that.
Even then, looks like my last few months data will stay skewed but would be good to work out what is going on if possible.
Please let me know if there are any thoughts on this or if you need more details to help.
Thanks in advance,
Paul
