Hi Guys,
I have just setup a few feeds from Home Assistant and they have been logging just find, except for the kWh/d feed that did not reset to Zero, when 12am hit in Sydney.
Not sure what I have done wrong.
Thanks in advance Rob
Hi Guys,
Are you viewing that from the Emoncms dashboard?
Have you set the timezone under your use profile?
Hi Brian,
I have my profile set to Australia/Sydney +11:00 and I am just viewing the data off the feed.
Also ignore the fact the KWH and KWH/D are different numbers I just started logging them at different times.
Ok, if emoncms.org, that is outside of my knowledge area - sorry.
[edit] Just a thought, are you feeding the data with a timestamp?
Could you post a screenshot of your Inputs page, so we can check how your creating the kwh feed.
What input API are you using to post the data?
What’s your emoncms.org username?
Thanks for the prompt response.
My username is rweisback
The data is being sent from a Vera Z-wave controller.
Input Page
Feed Page
Cheers Robbie.
I’ve taken a look at your account. The issue is that kwhd does not reset ad midnight it’s cumulative kwh/d. I would recommend just using kwh rather than kwh/d, see this user guide for how to view kwh/d graphs is bar graph form, you will need a few more days’ data to be able to view daily bar graph:
Hi Glyn,
Thanks for looking at this, I have been noticing that the kwh/d have been resetting the zero at UTC of 12:00 am which is 11:00 am in Sydney. Can that be setup to reflect the account times zone?
Regards Rob
