I was wondering if there is any update on this matter?
My voltages before the firmware update and after are not very accurate.
Hi, I think the outcome from the tests above indicated that the part supplied by jlcpcb wasn’t the usual specifications.
The AZ432 part can be used to swap with the TL432 on the modules, but would need additional solder skills.
I think my solder skills are good. Do you have a link or spec sheet for the new parts? Are the AZ432 a direct swap?
I see the spec sheet above.
Ordered 50 of them. Thanks for all the help.
