I have just run an update on a vanilla EmonPi from the update button on admin.
I see these errors
Start ATmega328 serial upload using avrdude with latest.hex
Discrete Sampling
avrdude -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/home/pi/emonpi/firmware/compiled/latest.hex
avrdude-original: Using autoreset DTR on GPIO Pin 7
avrdude-original: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude-original: Device signature = 0x1e950f (probably m328p)
avrdude-original: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude-original: erasing chip
avrdude-original: reading input file "/home/pi/emonpi/firmware/compiled/latest.hex"
avrdude-original: input file /home/pi/emonpi/firmware/compiled/latest.hex auto detected as Intel Hex
avrdude-original: writing flash (17886 bytes):
Writing | avrdude-original: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x1c
avrdude-original: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0xe0
avrdude-original: stk500_cmd(): programmer is out of sync
The last line is repeated hundreds of times, then
# | 100% 11.76s
avrdude-original: 17886 bytes of flash written
avrdude-original: verifying flash memory against /home/pi/emonpi/firmware/compiled/latest.hex:
avrdude-original: load data flash data from input file /home/pi/emonpi/firmware/compiled/latest.hex:
avrdude-original: input file /home/pi/emonpi/firmware/compiled/latest.hex contains 17886 bytes
avrdude-original: reading on-chip flash data:
Reading | avrdude-original: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x07
avrdude-original: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0x00
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude-original: failed to read all of flash memory, rc=-2
avrdude-original: stk500_disable(): protocol error, expect=0x14, resp=0xfc
strace: |autoreset: Broken pipe
avrdude-original done. Thank you.
Everything seems to be working fine. Has it corrected itself?
