Hi there, I have just started using emoncms in the last week to see the monitoring data from our heat pump. The electrical feed has lots of false readings, either 0 or 10000, whereas the real reading are 1500-1600 watts.
The electrical meter is an SM120M from openenergymonitor.org.
Is there a way to filter out these false data points or understand what could be causing them to happen.
The meter is installed inside the heat pump, maybe noise.
