When in process list of an input the value is operated with the operator *feed and the feed is virtual, the following process lists of the following inputs that have a higher id, are not processed.
The virtual feed used has its own process list and it is a RealTime data type. It works correctly, but when the feed is used in a input process list the problem appears.
