Is Wifi ESP8266 in IoTaWatt technically compliant in Japan?
All,
I need your help.
I wonder if wifi module ESP8266 has already been compliant in Japan?
Cheers,
I suggest The IoTaWatt forum is a better place to ask a question that is specifically about the operation and use of IoTaWatt. That is managed by Bob Lemaire, its creator, and he and the other users there are more likely to have the specific knowledge to help you.
The IoTaWatt forum uses the same software as this, but you must register a new account there. If the user name you have here is not taken, it might be helpful to have the same user name in both places.
If you post your question there, I’m sure he or somebody will get back to you quickly.
Thanks a lot! I will.
