Is node only format safe to disable?
The default emonhub.conf files for the EmonPi2 seem to have node_format_enable set to 0, with a comment stating that the Node module is deprecated in emonCMS 9+. I’m currently running emonCMS 11.x and don’t recall ever using a Node module. I haven’t been able to find any documentation explaining what the module is or was.
Is it safe to disable this old format when using the latest stable emonCMS versions?
Yes. It is a very old format for legacy purposes, but it is enabled by default so always disable it :slight_smile:
