So Apple introduced ATS (App Transport Security) with iOS 9. This meant that instantly all connections had to be HTTPS unless you specified exceptions. You could turn it off entirely if you wanted. However I haven’t specified any exceptions or turned it off entirely in the app so far. So @David_Hunnisett - it’s not talking to your server because you’re running on plain HTTP.
However, from January next year you won’t be allowed to turn off ATS at all unless you have a very good reason. It’s debatable whether it’s “a very good reason” for us. On one hand, we can’t control everyone’s emoncms install. On the other, we could mandate you have to be running HTTPS.
I am for the latter (and I’ll add a suitable error message). In this day and age and with free SSL certificates all over the place, we should all be running on HTTPS really.
Anyone against me mandating we use HTTPS? (If we don’t mandate it, the app could get rejected by Apple, or at the very least we’d need a good reason lined up for disabling ATS.)
Not had a chance to test properly yet. But looks nice! I’m up and running on my little pink 5c
I also noticed the HTTP issue when testing with my home emonPi.
When I link to my Emoncms.org account I can see my feeds but the app force closes if i try and click on them. How can I view debug?
Agree, in an ideal word all web traffic would be HTTPS. But I think if possible we should leave the option to the user (with sufficient warning messages).
I am aware a number of users (including solarPV installers) use the Android app on internal local network(s) to connect to the emonPi as an always-on wall mounted display. In this local network use case no traffic is going over the wider internet I don’t see a problem with HTTP.
I’m not sure how we would go about shipping each emonPi ready installed with pre-signed SSL certificates… This is a topic for another discussion!
Ah yes I forgot to mention. Apple allow HTTP if it’s on the same network as the device. So we can allow that even if we don’t turn off ATS.
We can try going through review with ATS turned off and see what they say, but they may come back and say we have to have it on. I’ve not had experience trying to get something like this through. I can ask around though.
Didn’t have to much time to play with the app but one thing that feels weird is when a feed is zero (for ex right now there is no solar production) you still have a fill under the zero mark, giving you the impression there is still something …
not sure this can become a simple 1 px line instead what we have now, at least we see it as zero
glad to hear HTTP can be used for a local network!
On 1.0(5) the time disappears when zoomed in too far. (Eric’s post above reminded me!). Is it possible to add half hours? Or maybe not allow the graph to be zoomed in too far?!?
Ugh. All of these graphing errors are annoying. I’m using the iOS version of the library that’s used on Android, but I think it’s not quite as mature and has lots of little issues. There’s tweaks I can make, but the API is pretty tricky!
Thanks for reporting these 2 things - I’ll sort them!
For the electricity meter, each pulse is 1 Wh. So 1000 pulses equal 1 kWh. I can obtain the kWh Feed using 3 - Log to feed - ePi_Opt_Pulse_kWh pictured below. I tried using kWh to Power but I get very odd output.
How do I create a Use Feed for Optical Pulse Watts?
I’m still having the force close issue whenever I try and view a graph. Same issue for emoncms.org and local Emoncms. Tried to illustrate the issue with a video. Sorry for the poor camera angle :
