I am getting ‘Invalid API key’
I double checked the key from the ‘Inputs’ device and also tried creating a new one.
tried different servers. Emoncms - user login gives me ‘Invalid API key’ emoncms.org/ gives me ‘Invalid API key’
emonpi/emoncms gives me ‘Failed to connect’
Then I setup a Raspberry Pi with Emoncms and also got ‘Invalid API key’
Your local emonCMS and emoncms.orgare different, so each has their own APIkey.
And are you using the correct one? To send data, you must use the “Read and Write” APIkey, get it from “Input API Help” on the top right corner of the Inputs page.
You can test it in your web browser by copying into the address line the example whose description starts “To post data from a remote device …”, when you should see “ok” and back on the Inputs page, the three power values should appear.
Ok, so you got my attention when you said get the key from ‘Input API Help’ and that key worked, so many bad info online saying to click on the gear.
Thank you for the help.
Why did you search the forum? Read what I wrote again, slowly and carefully. Go to the Inputs page of emonCMS (either, they are the same in this respect). Look at the examples showing how to send data.
Please explain. Where exactly is “online” - link and where it is on the page please; and what do you mean by “many bad info”. If it’s in the OEM documentation, I can do something about it. If not, you need to take it up with whoever manages the resource where you found the “bad info”.
I reported the error in their documentation to OpenEVSE Support. The ticket was most arrogantly closed with no response and no corrective action taken. You can read the ticket here: https://openev.freshdesk.com/support/tickets/75428
So, I’m afraid @Firefly, it’s lesson learned: Come to the horses mouth for reliable information next time you have a query about emonCMS.
