I have a 6kw Carrier air to water heat pump connected to a 6-zone underfloor heating system and a mains pressure 200 litre hot tank. The system has only one circulation pump, no buffer vessel and a three-port valve to switch between hot water heating and underfloor heating with the hot water as the priority service. I have fitted a heat pump monitoring system to find out if:- is the heat pump short cycling, is it switching off when few zones are calling for heat and is it working properly. The underfloor pipes are buried in thick screed/concrete so have a high thermal storage of heat and I operate the heat pump with an off-peak electricity supply. For most of the year I only turn the heat pump on during the off-peak hours - midnight to 5am (I have added an extra expensive hour until 6), 1pm to 4 pm and 8pm to 10 pm. This keeps my running costs down.
My emonPi monitoring system has temperature sensors on the top of the tank and the flow and return pipes leading to the hot tank. The electrical sensor measures the total electrical supply to the system including pumps. There is no connected immersion heater.
I attach copies of several graphs
1
This was last night when it was cold (below zero) outside and the heat pump seems to be de-icing regularly. It started at midnight and heated the hot water to 45C until 12:30 and then switched to underfloor heating.
2
This was during the day – it heated the water until 2:20 pm and then switched to underfloor heating – you can see 2 zones turning off completely at 14:30 and 14:40 and the thermostat cycling the heating before turning off and on each zone shown by the closely packed vertical lines.
One further thing I noted from all the graphs over the last month was that at no time did the heat pump turn off as a result of an inadequate load/flow.
I am surprised at the lack of switching off and wonder if my heat pump has a variable output run by an inverter and DC motor as, despite no buffer tank, it seems very tolerant of a completely zoned underfloor heating system. My heat pump is a 30AWH006XB.
I would be most grateful for any comments on my interpretation of these graphs and any further comments on what I can learn from them.
