Is there a way to schedule periodic restart if emonHUB ? Once in about three days I have MBUS communications freeze , sometimes no logs at all on emonHUB (empty). It recovered when I restart just the emonHUB. MQTT is up as my other sensors are able to send in Data so the issue is emonHUB > Driver > MBUS HW side of things.
Since its a non standard installation It is not worth debugging I suppose so wondering if there is some way for me to just periodically restart emonHUB automatically ?
My setup
MBUS adaptor from openenergymonitor Shop.
I have 4 heatmeters 3 ultego smart (measuring Ground , upstairs and DHW separately ) and a DANFOSS sonometer on the primary.
All other interfaces work fine . It is just the mbus interface that has some issue. Unfortunately , the heat meters were not from the shop. I will make the above checks you recommended next time this happens.
the emonhub screen just has a scroll of below … or sometimes it is blank with no logs…
Since these are not standard heat meters maybe difficult to debug so might as well better to have some script if you can recommend to periodically restart emnhub ? (tried with two shop mbus adaptors and have the same issue so not hardware)
Regards
Gopi
2024-01-13
14:39:50,923 DEBUG
MBUS Invalid MBUS data received 0 bytes 2004.0 ms
2024-01-13
14:39:53,129 DEBUG
MBUS Invalid MBUS data received 0 bytes 2004.8 ms
2024-01-13
14:39:53,330 DEBUG
MBUS Decoded MBUS data: None
2024-01-13
14:39:55,340 DEBUG
MBUS Invalid MBUS data received 0 bytes 2009.1 ms
2024-01-13
14:39:57,545 DEBUG
2024-01-13
14:39:57,745 DEBUG
2024-01-13
14:40:02,055 DEBUG
MBUS Invalid MBUS data received 0 bytes 2004.3 ms
2024-01-13
14:40:04,259 DEBUG MBUS Invalid MBUS data received 0 bytes, 2003.3 ms
2024-01-13 14:40:04,459 DEBUG MBUS Decoded MBUS data: None
2024-01-13 14:40:06,464 DEBUG MBUS Invalid MBUS data received 0 bytes 2003.9 ms
2024-01-13 14:40:08,669 DEBUG MBUS Invalid MBUS data received 0 bytes 2003.8 ms
2024-01-13 14:40:08,870 DEBUG MBUS Decoded MBUS data: None
2024-01-13 14:40:10,874 DEBUG MBUS Invalid MBUS data received 0 bytes 2003.9 ms
2024-01-13 14:40:13,079 DEBUG MBUS Invalid MBUS data received 0 bytes 2004.3 ms
2024-01-13
14:40:13,280 DEBUG
2024-01-13
14:40:15,285 DEBUG
MBUS Invalid MBUS data received 0 bytes 2003.7 ms
2024-01-13
14:40:17,489 DEBUG
MBUS Invalid MBUS data received 0 bytes 2003.3 ms
2024-01-13
14:40:17,690 DEBUG
2024-01-13
14:40:22,099 DEBUG
2024-01-13
14:40:24,304 DEBUG MBUS Invalid MBUS data received 0 bytes 2003.8 ms
2024-01-13 14:40:24,504 DEBUG MBUS Decoded MBUS data: None
2024-01-13 14:40:26,510 DEBUG MBUS Invalid MBUS data received 0 bytes 2004.9 ms
2024-01-13 14:40:28,715 DEBUG MBUS Invalid MBUS data received 0 bytes 2003.6 ms
2024-01-13 14:40:28,915 DEBUG MBUS Decoded MBUS data: None
2024-01-13 14:40:30,924 DEBUG MBUS Invalid MBUS data received 0 bytes 2007.9 ms
2024-01-13 14:40:33,129 DEBUG MBUS Invalid MBUS data received 0 bytes 2004.0 ms
MBUS Decoded
**pi@emonpi**:**~ $** sudo journalctl -f -u emonhub
-- Journal begins at Sun 2024-01-14 12:51:24 GMT. --
Jan 15 13:53:30 emonpi systemd[1]: Stopped emonHub data multiplexer.
Jan 15 13:53:30 emonpi systemd[1]: **emonhub.service: Consumed 36min 18.198s CPU time.**
Jan 15 13:53:30 emonpi systemd[1]: Starting emonHub data multiplexer...
Jan 15 13:53:30 emonpi systemd[1]: Started emonHub data multiplexer.
Jan 15 20:57:58 emonpi systemd[1]: Stopping emonHub data multiplexer...
Jan 15 20:58:00 emonpi systemd[1]: emonhub.service: Succeeded.
Jan 15 20:58:00 emonpi systemd[1]: Stopped emonHub data multiplexer.
Jan 15 20:58:00 emonpi systemd[1]: **emonhub.service: Consumed 10min 16.126s CPU time.**
Jan 15 20:58:00 emonpi systemd[1]: Starting emonHub data multiplexer...
Jan 15 20:58:00 emonpi systemd[1]: Started emonHub data multiplexer.
