Good day.
I am interfacing the CT CR8450 with Arduino and am using EmonLib in the code for interfacing it but at the serial monitor there is a lot of difference in the clamp meter and the sensor value. I have tried the many other codes for this but the issue is same. Can you helps guide me in the code how I can get accurate values from the CT. Thanks
