sudo systemctl disable openhab.service
echo 'deb http://dl.bintray.com/openhab/apt-repo2 stable main' | sudo tee /etc/apt/sources.list.d/openhab2.list
sudo apt-get update
sudo apt-get install openhab2
sudo apt-get install openhab2-addons
sudo nano /usr/lib/systemd/system/openhab2.service
[Unit]
Description=openHAB 2 - empowering the smart home
Documentation=http://docs.openhab.org
Documentation=https://community.openhab.org
Wants=network-online.target
After=network-online.target
[Service]
EnvironmentFile=/etc/default/openhab2
User=openhab
Group=openhab
WorkingDirectory=/usr/share/openhab2
PermissionsStartOnly=true
ExecStartPre=/bin/mkdir -p /var/log/openhab2
ExecStartPre=/bin/chown -R openhab:openhab /var/log/openhab2/
ExecStartPre=/bin/sh -c '/usr/bin/test -d /var/lib/openhab2/cache || /bin/mkdir /var/lib/openhab2/cache'
ExecStartPre=/bin/sh -c '/bin/mountpoint -q /var/lib/openhab2/cache || /bin/mount -t tmpfs tmpfs /var/lib/openhab2/cache'
ExecStartPre=/bin/sh -c '/usr/bin/test -d /var/lib/openhab2/tmp || /bin/mkdir /var/lib/openhab2/tmp'
ExecStartPre=/bin/sh -c '/bin/mountpoint -q /var/lib/openhab2/tmp || /bin/mount -t tmpfs tmpfs /var/lib/openhab2/tmp'
ExecStart=/usr/share/openhab2/start.sh server
ExecStop=/usr/share/openhab2/runtime/bin/stop
# Shutdown delay in seconds, before process is tried to be killed with KILL (if configured)
TimeoutStopSec=120
Restart=on-failure
[Install]
WantedBy=multi-user.target
sudo systemctl daemon-reload
sudo systemctl start openhab2
sudo systemctl status openhab2
sudo systemctl enable openhab2.service
sudo systemctl stop openhab2.service
sudo nano ./var/lib/openhab2/etc/org.ops4j.pax.logging.cfg
# File appender - openhab.log
log4j.appender.out=org.apache.log4j.RollingFileAppender
log4j.appender.out.layout=org.apache.log4j.PatternLayout
log4j.appender.out.layout.ConversionPattern=%d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
log4j.appender.out.file=${openhab.logdir}/openhab.log
log4j.appender.out.append=true
log4j.appender.out.maxFileSize=5MB
log4j.appender.out.maxBackupIndex=1
# File appender - events.log
log4j.appender.event=org.apache.log4j.RollingFileAppender
log4j.appender.event.layout=org.apache.log4j.PatternLayout
log4j.appender.event.layout.ConversionPattern=%d{yyyy-MM-dd HH:mm:ss.SSS} [%-26.26c{1}] - %m%n
log4j.appender.event.file=${openhab.logdir}/events.log
log4j.appender.event.append=true
log4j.appender.event.maxFileSize=5MB
log4j.appender.event.maxBackupIndex=1
sudo reboot
pi@emonpi(ro):~$ sudo systemctl status openhab2
? openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: active (running) since Sat 2017-03-11 19:29:17 UTC; 10min ago
Docs: http://docs.openhab.org
Process: 930 ExecStartPre=/bin/sh -c /bin/mountpoint -q /var/lib/openhab2/tmp || /bin/mount -t tmpfs tmpfs /var/lib/openhab2/tmp (code=exited, status=0/SUCCESS)
Process: 908 ExecStartPre=/bin/sh -c /usr/bin/test -d /var/lib/openhab2/tmp || /bin/mkdir /var/lib/openhab2/tmp (code=exited, status=0/SUCCESS)
Process: 892 ExecStartPre=/bin/sh -c /bin/mountpoint -q /var/lib/openhab2/cache || /bin/mount -t tmpfs tmpfs /var/lib/openhab2/cache (code=exited, status=0/SUCCESS)
Process: 877 ExecStartPre=/bin/sh -c /usr/bin/test -d /var/lib/openhab2/cache || /bin/mkdir /var/lib/openhab2/cache (code=exited, status=0/SUCCESS)
Process: 862 ExecStartPre=/bin/chown -R openhab:openhab /var/log/openhab2/ (code=exited, status=0/SUCCESS)
Process: 844 ExecStartPre=/bin/mkdir -p /var/log/openhab2 (code=exited, status=0/SUCCESS)
Main PID: 938 (karaf)
CGroup: /system.slice/openhab2.service
+- 938 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
+-1622 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var...
Mar 11 19:29:40 emonpi start.sh[938]: at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:318)
Mar 11 19:29:40 emonpi start.sh[938]: at org.eclipse.osgi.container.Module.doStart(Module.java:571)
Mar 11 19:29:40 emonpi start.sh[938]: at org.eclipse.osgi.container.Module.start(Module.java:439)
Mar 11 19:29:40 emonpi start.sh[938]: at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
Mar 11 19:29:40 emonpi start.sh[938]: at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
Mar 11 19:29:40 emonpi start.sh[938]: at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
Mar 11 19:29:40 emonpi start.sh[938]: at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
Mar 11 19:29:40 emonpi start.sh[938]: at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
Mar 11 19:29:40 emonpi start.sh[938]: at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
Mar 11 19:29:40 emonpi start.sh[938]: at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
It is working right now. But looks like I need to put the FS in RW mode when installing bindings or UI/Actions etc. Otherwise they end op in an infinite loop.
