Jose
I also have a Synology NAS running DSM 7. When you get your problem resolved I would very much like to get the install instructions from you as I would like to add EMONCMS to my NAS.
Regards
John
For know the solution i found is to use Synology Virtual Machine Manager to create a Ubuntu 20.04 server virtual machine and install emoncms on it
It might not be the perfect solution, but it works ok and it does not requires many resources from the NAS. Also it’s future proof and portable between systems.
Yes, it’s the .ini files. You are right. Anyway, it worked ok. The only problem was when i tried to migrate the database from the “old” system (i’m still using DSM 6.2). Since the old system uses a previous version, that did not worked well.
Anyway, since it’s possible to make snapshots of the VM, it’s easy to recover the working state. The problem is that i did not made that, since I’m still doing experiments and did not done the snapshots
