boelle
(Bo Herrmannsen)
1
this is a SELFHOSTED install of emoncms
so the pi has been running for almost a week now and everything seems fine
now suddenly the feeds stopped updating in the middle of the night, inputs still works fine, but the feeds do not get updated
if keeping in mind that things worked last night and without touching anything feed just stopped updating, what would the first troubleshoot step be?
boelle
(Bo Herrmannsen)
2
just checked date and time
Sun 5 May 09:31:02 UTC 2019
boelle
(Bo Herrmannsen)
3
i have a pi sending data to emoncms with this script
https://github.com/boelle/Rpi-Heating-Control/blob/master/heatcontrol.py
and the time on that one is: Sun 5 May 10:32:03 BST 2019
boelle
(Bo Herrmannsen)
5
LOG
LAST ENTRIES ON THE LOG FILE
2019-05-05 09:06:32.420|ERROR|feedwriter.php|Starting feedwriter script
2019-05-05 09:06:34.632|WARN|emoncms_mqtt.php|Not connected, retrying connection
2019-05-05 09:06:34.855|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
update log
Starting update via service-runner-update.sh (v2.0) >
Filesystem is unlocked - Write access
type ' rpi-ro ' to lock
- emonSD version: emonSD-26Oct17
emonSD base image check passed...continue update
git pull /home/pi/emonpi
* master
wifiap
On branch master
Your branch is up-to-date with 'origin/master'.
Untracked files:
(use "git add <file>..." to include in what will be committed)
1
nothing added to commit but untracked files present (use "git add" to track)
Already up-to-date.
Main Update Script
Date: Mon 29 Apr 19:54:23 UTC 2019
EUID: 1000
usrdir: /home/pi
type: all
firmware: rfm69pi
Checking environment:
- pi user found
EUID: 1000
Hardware detected: rfm2pi
Stopping emonPiLCD service
Display update message on LCD
I2C LCD NOT DETECTED on either 0x['27', '3f'] ...exiting LCD script
Hit http://ppa.launchpad.net xenial InRelease
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://repo.mosquitto.org jessie InRelease
Ign http://dl.bintray.com stable InRelease
Hit http://archive.raspberrypi.org jessie InRelease
Get:1 http://dl.bintray.com stable Release.gpg [821 B]
Get:2 http://dl.bintray.com stable Release [6,051 B]
Hit http://ppa.launchpad.net xenial/main Sources
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://ppa.launchpad.net xenial/main armhf Packages
Hit http://ppa.launchpad.net xenial/main Translation-en
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Hit http://repo.mosquitto.org jessie/main armhf Packages
Ign http://repo.mosquitto.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Get:3 http://dl.bintray.com stable/main armhf Packages [77.8 kB]
Ign http://dl.bintray.com stable/main Translation-en_GB
Fetched 84.6 kB in 1min 1s (1,369 B/s)
Reading package lists...
Building dependency tree...
Reading state information...
rng-tools is already the newest version.
python-gpiozero is already the newest version.
python-rpi.gpio is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 99 not upgraded.
Requirement already up-to-date: paho-mqtt in /usr/local/lib/python2.7/dist-packages (1.4.0)
You are using pip version 18.1, however version 19.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
git pull /home/pi/RFM2Pi
* master
On branch master
nothing to commit, working directory clean
Already up-to-date.
git pull /home/pi/usefulscripts
* master
On branch master
Already up-to-date.
git pull /home/pi/huawei-hilink-status
* master
On branch master
Already up-to-date.
git pull /home/pi/oem_openHab
* master
On branch master
Already up-to-date.
git pull /home/pi/oem_node-red
* master
On branch master
Already up-to-date.
RFM69Pi Firmware Update
Getting latest RFM69Pi release info from github
Latest RFM69Pi firmware: V1.4.0
downloading latest RFM69Pi firmware from github releases:
https://github.com/openenergymonitor/RFM2Pi/releases/download/1.4.0/firmware.hex
Saving to /home/pi/data/firmware/rfm69pi-1.4.0.hex
Flashing RFM69Pi with V 1.4.0
avrdude-original: Version 6.1, compiled on Jul 7 2015 at 10:29:47
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyAMA0
Using Programmer : arduino
Overriding Baud Rate : 38400
avrdude-original: Using autoreset DTR on GPIO Pin 7
avrdude-original: stk500_recv(): programmer is not responding
avrdude-original: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude-original: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude-original done. Thank you.
strace: |autoreset: Broken pipe
Flashing RFM69Pi with V 1.4.0 done
Start emonhub update script:
emonHub update started
- usr directory: /home/pi
git pull /home/pi/emonhub
K0den-wibeee_interface
* emon-pi
hmm01i-syslogging
On branch emon-pi
Your branch is up-to-date with 'origin/emon-pi'.
Already up-to-date.
emonhub.service already installed
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Emoncms update started
Emoncms update script V1.3 (26th March 2019)
- emoncms directory: /var/www/emoncms
current settings.php md5: 468b110786bf0ab60a856fa3c0036f0f
Default settings.php md5: 468b110786bf0ab60a856fa3c0036f0f
settings.php has NOT been user modifed
Checking status of /var/www/emoncms git repository
- git branch: stable
- no local changes
- running: git pull origin stable
From https://github.com/emoncms/emoncms
* branch stable -> FETCH_HEAD
Already up-to-date.
NEW default settings.php md5: 468b110786bf0ab60a856fa3c0036f0f
settings.php not updated
Updating Emoncms Modules
Updating /var/www/emoncms/Modules/app module
- git tags: 1.2.0-21-g8edcc30
- no local changes
From https://github.com/emoncms/app
Already up-to-date.
Updating /var/www/emoncms/Modules/config module
- git tags: 1.0.0-8-g5e96633
- no local changes
From https://github.com/emoncms/config
Already up-to-date.
Updating /var/www/emoncms/Modules/dashboard module
- git tags: 1.3.1-36-g8be171b
- no local changes
From https://github.com/emoncms/dashboard
Already up-to-date.
Updating /var/www/emoncms/Modules/device module
- git branch: master
- git tags: 1.1.1-35-gda7fa4e
- no local changes
- running: git pull origin master
From https://github.com/emoncms/device
* branch master -> FETCH_HEAD
Already up-to-date.
Updating /var/www/emoncms/Modules/graph module
- git tags: 1.2.1-66-g91d4db5
- no local changes
From https://github.com/emoncms/graph
Already up-to-date.
Updating /var/www/emoncms/Modules/wifi module
- git tags: 1.2.0-33-g2f37618
- no local changes
From https://github.com/emoncms/wifi
Already up-to-date.
Updating postprocess module
- git branch: emonpi
fatal: No names found, cannot describe anything.
- git tags:
- no local changes
- running: git pull origin emonpi
From https://github.com/emoncms/postprocess
* branch emonpi -> FETCH_HEAD
Already up-to-date.
Updating sync module
- git tags: 1.0.0-7-gc391cd2
- no local changes
From https://github.com/emoncms/sync
Already up-to-date.
Updating backup module
- git tags: 1.1.5-37-gf55d616
- no local changes
From https://github.com/emoncms/backup
Already up-to-date.
Auto Installation of Emoncms Modules
- graph module already installed
- device module already installed
- postprocess module already installed
- sync module already installed
- backup module already installed
www-data : www-data video systemd-journal
SERVICES
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Update Emoncms database
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
- sudo /etc/init.d/openhab restart
Restarting openhab (via systemctl): openhab.service.
● openhab.service - Starts and stops the openHAB Home Automation Bus
Loaded: loaded (/usr/lib/systemd/system/openhab.service; enabled)
Active: active (running) since Mon 2019-04-29 20:00:14 UTC; 1s ago
Docs: http://www.openhab.org
Process: 18964 ExecStartPre=/usr/share/openhab/bin/setpermissions.sh (code=exited, status=0/SUCCESS)
Main PID: 19017 (openhab.sh)
CGroup: /system.slice/openhab.service
├─19017 /bin/sh /usr/share/openhab/bin/openhab.sh -o
└─19045 /usr/bin/java -Dlogback.configurationFile=/etc/openhab/logback.xml -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true -Djetty.port=8080 -Dopenhab.configfile=/etc/openhab/configurations/openhab.cfg -Dopenhab.configdir=/etc/openhab/configurations -Dopenhab.logdir=/var/log/openhab -Dsmarthome.userdata=/var/lib/openhab -Djetty.home=/usr/share/openhab -Djetty.port.ssl=8443 -Djetty.config=/etc/openhab/jetty -Djetty.logs=/var/log/openhab -Djetty.rundir=/usr/share/openhab -Dfelix.fileinstall.dir=/usr/share/openhab/addons -Dfelix.fileinstall.filter=.*\.jar -Djava.library.path=/usr/share/openhab/lib -Djava.security.auth.login.config=/etc/openhab/login.conf -Dorg.quartz.properties=/etc/openhab/quartz.properties -Dequinox.ds.block_timeout=240000 -Dequinox.scr.waitTimeOnBlock=60000 -Dfelix.fileinstall.active.level=4 -Djava.awt.headless=true -jar /usr/share/openhab/server/plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar -configuration /var/lib/openhab/workspace -data /var/lib/openhab/workspace -console 5555
Apr 29 20:00:12 emonpi setpermissions.sh[18964]: setting owner openhab:openhab recursively for /var/lib/openhab
Apr 29 20:00:12 emonpi setpermissions.sh[18964]: setting permissions and owner openhab:openhab recursively for /var/log/openhab
Apr 29 20:00:12 emonpi setpermissions.sh[18964]: setting permissions and owner openhab:openhab recursively for /etc/openhab/configurations
Apr 29 20:00:14 emonpi setpermissions.sh[18964]: setting permissions and owner openhab:openhab for /usr/share/openhab/webapps/static
Apr 29 20:00:14 emonpi setpermissions.sh[18964]: setting permissions and owner openhab:openhab for /etc/openhab/jetty/etc/keystore
Apr 29 20:00:14 emonpi setpermissions.sh[18964]: setting permissions and owner openhab:openhab for /etc/openhab/configurations/users.cfg
Apr 29 20:00:14 emonpi systemd[1]: Started Starts and stops the openHAB Home Automation Bus.
Installing emoncms logrotate...
Now setting up Logrotate...
Backing up old logrotate configuration...
Linked to new logrotate configuration...
Backing up old logrotate cron job...
Linked to new logrotate cron job...
Completed
setup logrotate state & logfile in /var/log/logrotate
mkdir: cannot create directory ‘/var/log/logrotate’: File exists
Completed
Running logrotate...
set log rotate config owner to root
chown: changing ownership of ‘/etc/logrotate.conf’: Read-only file system
Emoncms update script complete
Starting emonPi LCD service..
Filesystem is locked - Read Only access
type ' rpi-rw ' to unlock
emonPi update done: Mon 29 Apr 20:00:44 UTC 2019
restarting service-runner
boelle
(Bo Herrmannsen)
6
timezone in my account (inside emoncms) and the one in raspi config match up
and this is the low write sd card image if i forgot to mention that
borpin
(Brian Orpin)
7
Almost certainly /log/var filling up. Daft suggestion as it is self hosted…
boelle
(Bo Herrmannsen)
8
and how do i confirm if that is the case?
i thought it cleared things like that on it’s own
boelle
(Bo Herrmannsen)
9
that one suggest that it has been fixed
and then again my input works fine and that is not what the link is about
so i’m still puzzled,
@TrystanLea @glyn.hudson if something is filling up should the user not get a warning and simple instructions on how to fix it?
borpin
(Brian Orpin)
10
df -h
So it should if configured correctly. I have been saying this is a problem for ages with little traction…
The fix, as it stands, doesn’t work IMNSHO.
I believe this fix does on an OCT18 SD image (and provides some additional log retention).
boelle
(Bo Herrmannsen)
11
Filesystem Size Used Avail Use% Mounted on
/dev/root 3.4G 2.2G 1.1G 67% /
devtmpfs 237M 0 237M 0% /dev
tmpfs 241M 0 241M 0% /dev/shm
tmpfs 241M 4.5M 237M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 241M 0 241M 0% /sys/fs/cgroup
tmpfs 40M 28K 40M 1% /var/lib/openhab
tmpfs 1.0M 4.0K 1020K 1% /var/lib/dhcpcd5
tmpfs 1.0M 0 1.0M 0% /var/lib/dhcp
tmpfs 50M 520K 50M 2% /var/log
tmpfs 1.0M 0 1.0M 0% /var/tmp
tmpfs 30M 40K 30M 1% /tmp
/dev/mmcblk0p1 60M 22M 39M 37% /boot
/dev/mmcblk0p3 969M 41M 879M 5% /home/pi/data
does not look full to me, or am i wrong?
borpin
(Brian Orpin)
12
Nope you are correct.
I see you are posting by API, is there anything in the log in the admin screen?
You can change the log level in settings.php to INFO so you will see an entry each time you post to emoncms via the API.
What do you get as your responses to the GET?
boelle
(Bo Herrmannsen)
13
i will have to check, put i assume the GET is ok since INPUTS are updated
boelle
(Bo Herrmannsen)
14
so if i do the copy log to clipboard i only get this
2019-05-05 10:35:41.007|ERROR|feedwriter.php|Starting feedwriter script
2019-05-05 10:35:43.240|WARN|emoncms_mqtt.php|Not connected, retrying connection
2019-05-05 10:35:43.450|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
borpin
(Brian Orpin)
16
Yes good point. Change the logging level and see if anything additional that will help.
Can you post output from…
systemctl status feedwriter.service
borpin
(Brian Orpin)
17
It isn’t actually an error. The log should be as INFO for that message.
boelle
(Bo Herrmannsen)
18
pi@emonpi(ro):~$ systemctl status feedwriter.service
● feedwriter.service - Emoncms feedwriter script
Loaded: loaded (/var/www/emoncms/scripts/services/feedwriter/feedwriter.service; disabled)
Active: active (running) since Sun 2019-05-05 10:35:33 UTC; 4min 11s ago
Docs: emoncms/install-service-feedwriter.md at master · emoncms/emoncms · GitHub
Main PID: 2262 (php)
CGroup: /system.slice/feedwriter.service
└─2262 /usr/bin/php /var/www/emoncms/scripts/feedwriter.php
pi@emonpi(ro):~$
borpin
(Brian Orpin)
19
That looks OK,
On the admin page, under the services
How many points pending write?
boelle
(Bo Herrmannsen)
20
0
feedwriter Active Running - sleep 60s 0 feed points pending write
