Stranged thing happened two days ago.
My emoncms.org (so logging to the hosting environment, not local) stopped logging data. Reset did not work.
I checked this issue:
Any further suggestions?
Beste regards,
Antoine
Beste regards,
Antoine
Hello @Antoine_Maartens
Any indication of what might be the issue from the emonhub log emonHub Overview — OpenEnergyMonitor 0.0.1 documentation?
Check that /var/log/
isn’t full (100%).
df -h
For a reason yet unknown to me I lost my wired ethernet connection from the emonhub / pi.
For now I switched to wireless and re-established the connectivity.
I now see data moving again - I think I lost a day or two.
I’ll work on the wired connectivity later.
Thanx for the help!
Best regards,
Antoine
Goodevening,
Upload stopped again since 43 hours.
I believe there is enough diskspace on the device:
/dev/root 4.1G 2.5G 1.5G 64% /
devtmpfs 430M 0 430M 0% /dev
tmpfs 462M 0 462M 0% /dev/shm
tmpfs 462M 47M 415M 11% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 462M 0 462M 0% /sys/fs/cgroup
tmpfs 1.0M 8.0K 1016K 1% /var/lib/php/sessions
tmpfs 1.0M 0 1.0M 0% /var/tmp
tmpfs 30M 0 30M 0% /tmp
/dev/mmcblk0p3 9.9G 259M 9.1G 3% /var/opt/emoncms
/dev/mmcblk0p1 253M 50M 203M 20% /boot
log2ram 50M 2.4M 48M 5% /var/log
tmpfs 93M 0 93M 0% /run/user/1000
I am more or less at a loss where to look to get the upload process to emoncms.org going again. Any suggestions very welcome.
Best regards,
Antoine
And it started working again by fiddling with the emonbase / emonpi.
What could be going on?
Depends what ‘fiddling’ you did.
You need to look at the logs. If on the Input page, the last update time has stopped updating, check the emonhub log and see what that says.
[edit]
Was it just the online data or the local data as well?
