Hi
I did post a while back about my problem but got no replies. Since then I have played about more but got no further
The issue is that my feeds on my remote site just stopped updating. I have 2 Arduino units that push data via ESP8266 and both stopped at the same time. The original emoncms version was 9.7.2 but installing a fresh 9.8.10 gives the same problem
The data is sent using the GET command as follows
GET http://www.markderbyshire.co.uk/emoncms1/input/post?node=solar&fulljson={“rssi”:78}&apikey=myApiKey
with no updating
In the Arduino Serial monitor I get back the following reply
"Recv 129 bytes
SEND OK
+IPD,187:HTTP/1.0 400 Bad request
Cache-Control: no-cache
Connection: close
Content-Type: text/html
400 Bad request
Your browser sent an invalid request. CLOSED"If I send the string as follows from a browser I get the OK response and the inputs update.
I have contacted my server host and they are seeing the data coming in
This was working fine for over a year and then just stopped
TIA
Mark
