Hell there,
trying to get some help for strange issue.
All I did was full update via the GUI from v10.2.7 to v10.4
Everything seems to work fine, except… my Inputs screen just displays “Loading” no no inputs are shown. — just a blank page.
<details><summary>LAST ENTRIES ON THE LOG FILE</summary><br />
/var/log/emonhub/emonhub.log.1 truncated to make room for update log<br />
Starting update via service-runner-update.sh (v3.0) ><br />
Filesystem Size Used Avail Use% Mounted on<br />
/dev/root 4.0G 2.3G 1.5G 61% /<br />
devtmpfs 866M 0 866M 0% /dev<br />
tmpfs 995M 0 995M 0% /dev/shm<br />
tmpfs 995M 8.5M 987M 1% /run<br />
tmpfs 5.0M 4.0K 5.0M 1% /run/lock<br />
tmpfs 995M 0 995M 0% /sys/fs/cgroup<br />
tmpfs 30M 16K 30M 1% /tmp<br />
tmpfs 1.0M 0 1.0M 0% /var/tmp<br />
tmpfs 1.0M 0 1.0M 0% /var/lib/php/sessions<br />
/dev/mmcblk0p1 253M 52M 201M 21% /boot<br />
/dev/mmcblk0p3 10G 937M 8.6G 10% /var/opt/emoncms<br />
log2ram 50M 1.9M 49M 4% /var/log<br />
tmpfs 199M 0 199M 0% /run/user/1000<br />
- emonSD version: emonSD-17Oct19<br />
- supported images: emonSD-08May21 emonSD-24Jul20 emonSD-02Oct19 emonSD-17Oct19<br />
- emonSD base image check passed...continue update<br />
git pull /opt/openenergymonitor/EmonScripts<br />
master<br />
* stable<br />
On branch stable<br />
Your branch is up to date with 'origin/stable'.<br />
<br />
nothing to commit, working tree clean<br />
Already up to date.<br />
-------------------------------------------------------------<br />
Main Update Script<br />
Date: Sun 13 Jun 07:01:19 EST 2021<br />
EUID: 1000<br />
openenergymonitor_dir: /opt/openenergymonitor<br />
type: all<br />
firmware: emonpi<br />
Reading package lists...<br />
Building dependency tree...<br />
Reading state information...<br />
python3-pip is already the newest version (18.1-5+rpt1).<br />
0 upgraded, 0 newly installed, 0 to remove and 195 not upgraded.<br />
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple<br />
Requirement already satisfied: redis in /home/pi/.local/lib/python3.7/site-packages (3.5.3)<br />
Hardware detected: rfm2pi<br />
Running apt-get update<br />
Hit:1 http://archive.raspberrypi.org/debian buster InRelease<br />
Hit:2 https://deb.nodesource.com/node_10.x buster InRelease<br />
Get:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]<br />
Fetched 15.0 kB in 2s (9,760 B/s)<br />
git pull /opt/openenergymonitor/emonpi<br />
* master<br />
On branch master<br />
Your branch is up to date with 'origin/master'.<br />
<br />
Fetching origin<br />
git pull /opt/openenergymonitor/RFM2Pi<br />
* master<br />
<br />
Start emonhub update script:<br />
emonHub update<br />
Migrating from emon-pi branch to stable branch<br />
Updating /opt/openenergymonitor/emonhub<br />
- current branch: emon-pi<br />
WARNING local changes in /opt/openenergymonitor/emonhub - Module not updated<br />
- git status: On branch emon-pi<br />
Your branch is behind 'origin/emon-pi' by 13 commits, and can be fast-forwarded.<br />
(use "git pull" to update your local branch)<br />
<br />
Changes not staged for commit:<br />
(use "git add ..." to update what will be committed)<br />
(use "git checkout -- ..." to discard changes in working directory)<br />
<br />
modified: src/interfacers/__init__.py<br />
<br />
Untracked files:<br />
(use "git add ..." to include in what will be committed)<br />
<br />
src/interfacers/EmonHubVEDirectInterfacer2.py<br />
src/interfacers/EmonHubVEDirectInterfacer3.py<br />
src/src<br />
<br />
no changes added to commit (use "git add" and/or "git commit -a")<br />
<br />
Start emoncms update:<br />
Update Emoncms Core<br />
Updating /var/www/emoncms<br />
- current branch: stable<br />
- local changes: no<br />
- git fetch: Fetching origin<br />
Already on 'stable'<br />
- git checkout: Your branch is up to date with 'origin/stable'.<br />
- git pull: Already up to date.<br />
- database update: no changes<br />
- component updated<br />
Update Emoncms Services<br />
emoncms_mqtt.service already installed<br />
feedwriter.service already installed<br />
service-runner.service already installed<br />
<br />
Reloading systemctl deamon<br />
Restarting Services...<br />
- sudo systemctl restart feedwriter.service<br />
--- ActiveState=active ---<br />
- sudo systemctl restart emoncms_mqtt.service<br />
- sudo systemctl restart emonhub.service<br />
/opt/openenergymonitor/EmonScripts/sudoers.d/emoncms-rebootbutton: parsed OK<br />
emonPi emoncms admin reboot button sudoers updated<br />
<br />
Update Emoncms Modules<br />
Updating /var/www/emoncms/Modules/app<br />
Updating /var/www/emoncms/Modules/config<br />
Updating /var/www/emoncms/Modules/dashboard<br />
Updating /var/www/emoncms/Modules/device<br />
Updating /var/www/emoncms/Modules/graph<br />
Updating /var/www/emoncms/Modules/setup<br />
Updating /var/www/emoncms/Modules/wifi<br />
Updating /opt/emoncms/modules/backup<br />
- running module install/update script<br />
Backup module installation and update script<br />
- Loading EmonScripts config.ini<br />
- config.cfg already exists, left unmodified<br />
- Backup module symlink already exists<br />
- PHP Version: 7.3<br />
- Creating /etc/php/7.3/mods-available/emoncmsbackup.ini<br />
post_max_size = 3G<br />
upload_max_filesize = 3G<br />
upload_tmp_dir = /var/opt/emoncms/backup/uploads<br />
- phpenmod emoncmsbackup<br />
- /var/opt/emoncms/backup already exists<br />
- /var/opt/emoncms/backup/uploads already exists<br />
- restarting apache<br />
Updating /opt/emoncms/modules/demandshaper<br />
DemandShaper module installation script<br />
- reinstalling demandshaper.service<br />
Removed /etc/systemd/system/multi-user.target.wants/demandshaper.service.<br />
Created symlink /etc/systemd/system/multi-user.target.wants/demandshaper.service → /lib/systemd/system/demandshaper.service.<br />
- Service ActiveState=active<br />
Updating /opt/emoncms/modules/postprocess<br />
Updating /opt/emoncms/modules/sync<br />
Updating /opt/emoncms/modules/usefulscripts<br />
/opt/openenergymonitor/EmonScripts/sudoers.d/wifi-sudoers: parsed OK<br />
wifi sudoers entry updated<br />
<br />
EmonPi LCD Update<br />
i2c-tools is already the newest version (4.1-1).<br />
python3-smbus is already the newest version (4.1-1).<br />
python3-gpiozero is already the newest version (1.6.2-1).<br />
python3-rpi.gpio is already the newest version (0.7.0-0.1~bpo10+4).<br />
Requirement already satisfied: paho-mqtt in /home/pi/.local/lib/python3.7/site-packages (1.5.0)<br />
Requirement already satisfied: xmltodict in /home/pi/.local/lib/python3.7/site-packages (0.12.0)<br />
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.21.0)<br />
- reinstalling emonPiLCD.service<br />
Removed /etc/systemd/system/emonPiLCD.service.<br />
Removed /etc/systemd/system/multi-user.target.wants/emonPiLCD.service.<br />
- installing emonPiLCD.service<br />
Created symlink /etc/systemd/system/multi-user.target.wants/emonPiLCD.service → /opt/openenergymonitor/emonpi/lcd/emonPiLCD.service.<br />
Created symlink /etc/systemd/system/emonPiLCD.service → /opt/openenergymonitor/emonpi/lcd/emonPiLCD.service.<br />
Stopping emonPiLCD service<br />
Display update message on LCD<br />
EmonPi Firmware Update (Discrete Sampling)<br />
Start ATmega328 serial upload using avrdude with latest.hex<br />
Attempt: 1<br />
avrdude -c arduino -p ATMEGA328P -P /dev/ttyAMA0 -b 115200 -U flash:w:/opt/openenergymonitor/emonpi/firmware/compiled/latest.hex<br />
Note: progress written to logfile /var/log/emoncms/firmware.log<br />
<br />
avrdude-original: Using autoreset DTR on GPIO Pin 7<br />
strace: |autoreset: Broken pipe<br />
<br />
ERROR: Not in sync<br />
Attempt: 2<br />
<br />
<br />
Attempt: 3<br />
<br />
<br />
<br />
waiting for emonpi to stop controlling LCD<br />
<br />
emonPi update done: Sun 13 Jun 07:14:33 EST 2021<br />
restarting service-runner</details><br />
