I’ve recently resurrected an old emonPi with a new SD card from the OEM shop.
Inputs and Feeds are showing up as Null.
Log looks as follows: (Lots of not authenticated - but not sure what this means)
All of my services are running and are Green
LAST ENTRIES ON THE LOG FILE
2022-09-27 13:57:59.051|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2022-09-27 14:35:15.815|WARN|emoncms_mqtt.php|Not connected, retrying connection
2022-09-27 14:35:15.837|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2022-09-27 14:45:23.164|WARN|index.php|406 Not Acceptable|admin
2022-09-27 15:13:53.314|ERROR|index.php|Not Authenticated|input/view
2022-09-27 15:16:51.066|WARN|sync_model.php|remote save
2022-09-27 15:16:51.303|WARN|sync_model.php|{"success":false,"message":"Incorrect authentication"}
2022-09-27 15:56:18.560|WARN|sync_model.php|remote save
2022-09-27 15:56:18.795|WARN|sync_model.php|{"success":false,"message":"Incorrect authentication"}
2022-09-27 15:57:25.737|ERROR|index.php|Not Authenticated|wifi
2022-09-27 16:07:12.363|WARN|emoncms_mqtt.php|Not connected, retrying connection
2022-09-27 16:07:12.460|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2022-09-27 16:07:12.405|ERROR|index.php|Not Authenticated|feed/list
2022-09-27 16:07:12.497|ERROR|index.php|Not Authenticated|feed/list
2022-09-27 16:07:12.815|ERROR|index.php|Not Authenticated|feed/list
2022-09-27 16:07:12.993|ERROR|index.php|Not Authenticated|feed/list
2022-09-27 16:07:13.071|ERROR|index.php|Not Authenticated|feed/list
2022-09-27 16:07:13.168|ERROR|index.php|Not Authenticated|feed/list
2022-09-27 16:07:13.321|ERROR|index.php|Not Authenticated|feed/list
2022-09-27 16:14:16.095|ERROR|index.php|Not Authenticated|admin/view
2022-09-27 16:14:19.817|ERROR|index.php|Not Authenticated|feed/list
2022-09-27 16:23:29.391|WARN|emoncms_mqtt.php|Not connected, retrying connection
2022-09-27 16:23:29.416|WARN|emoncms_mqtt.php|Connecting to MQTT server: Connection Accepted.: code: 0
2022-09-30 07:55:21.092|ERROR|index.php|Not Authenticated|input/view
2022-09-30 07:55:21.653|ERROR|index.php|Not Authenticated|input/view
Hello @goldfish do you see any activity in the EmonHub log? (Available via the main emoncms setup menu) Data is initially read from the emonPi energy monitoring board using EmonHub before it is then forwarded to the emoncms installation. It may be getting stuck at that stage… alternatively it may be worth using Admin > Update to update the firmware on the emonPi to see if that brings it back to life…
e.g:
Hi Trystan
Success - looks like the firmware update solved it. Getting my main and solar inputs and have logged to feeds.
Conor
