@TrystanLea
The PowerWalls were installed 11 days ago but are not yet operational due to a fault. It’s been very difficult to get Tesla service but an engineer is due on site tomorrow.
Once up and running, I’m happy to be a ‘test bed’ on this.
My first intention is to try to modify the PowerWallInterfacer.
I’ve previously seen the link you’ve provided but frankly find it difficult to understand. This link might also be helpful …
In anticipation I already have a dedicated RPi on site running emoncms. Of course I don’t yet have a URL for PowerWall to put into the PowerWallInterfacer which explains why I’m getting the following output when I restart emonhub. As an aside - watchman is another RPi on site which collects data from 4 x EmonTx/RPi’s - inverter generation meter, grid meter, pool and EV charger.
2020-06-29 15:15:16,176 INFO MainThread Opening hub...
2020-06-29 15:15:16,177 INFO MainThread Logging level set to DEBUG
2020-06-29 15:15:16,177 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2020-06-29 15:15:16,179 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2020-06-29 15:15:18,182 WARNING MainThread Device communication error - check settings
2020-06-29 15:15:18,183 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2020-06-29 15:15:19,185 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2020-06-29 15:15:20,187 INFO MainThread Setting RFM2Pi group: 210 (210g)
2020-06-29 15:15:21,190 INFO MainThread Setting RFM2Pi quiet: 1 (1q)
2020-06-29 15:15:22,192 INFO MainThread Setting RFM2Pi calibration: 230V (1p)
2020-06-29 15:15:23,194 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2020-06-29 15:15:23,195 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2020-06-29 15:15:23,198 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2020-06-29 15:15:23,201 DEBUG MainThread Setting MQTT pubchannels: ['ToRFM12']
2020-06-29 15:15:23,202 DEBUG MainThread Setting MQTT subchannels: ['ToEmonCMS']
2020-06-29 15:15:23,203 INFO MainThread Setting MQTT node_format_enable: 1
2020-06-29 15:15:23,203 INFO MainThread Setting MQTT nodevar_format_enable: 1
2020-06-29 15:15:23,204 INFO MainThread Setting MQTT nodevar_format_basetopic: emon/
2020-06-29 15:15:23,205 INFO MainThread Creating EmonHubTeslaPowerWallInterfacer 'PowerWall'
2020-06-29 15:15:23,206 INFO MainThread Setting PowerWall name: powerwall
2020-06-29 15:15:23,207 INFO MainThread Setting PowerWall url: http://POWERWALL-IP/api/system_status/soe
2020-06-29 15:15:23,208 INFO MainThread Setting PowerWall readinterval: 10
2020-06-29 15:15:23,208 DEBUG MainThread Setting PowerWall pubchannels: ['ToEmonCMS']
2020-06-29 15:15:23,215 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'To_watchman'
2020-06-29 15:15:23,217 DEBUG MainThread Setting To_watchman pubchannels: ['ToRFM12']
2020-06-29 15:15:23,218 DEBUG MainThread Setting To_watchman subchannels: ['ToEmonCMS']
2020-06-29 15:15:23,219 INFO MainThread Setting To_watchman apikey: set
2020-06-29 15:15:23,220 INFO MainThread Setting To_watchman url: http://192.168.1.10/emoncms
2020-06-29 15:15:23,220 INFO MainThread Setting To_watchman senddata: 1
2020-06-29 15:15:23,221 INFO MainThread Setting To_watchman sendstatus: 0
2020-06-29 15:15:33,292 WARNING PowerWall PowerWall couldn't send to server: HTTPConnectionPool(host='powerwall-ip', port=80): Max retries exceeded with url: /api/system_status/soe (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x75580790>: Failed to establish a new connection: [Errno -2] Name or service not known'))
2020-06-29 15:15:33,296 WARNING PowerWall Exception caught in PowerWall thread. Traceback (most recent call last):
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 32, in wrapper
return f(*args)
File "/opt/openenergymonitor/emonhub/src/emonhub_interfacer.py", line 99, in run
rxc = self.read()
File "/opt/openenergymonitor/emonhub/src/interfacers/EmonHubTeslaPowerWallInterfacer.py", line 49, in read
jsonstr = reply.text.rstrip()
UnboundLocalError: local variable 'reply' referenced before assignment
2020-06-29 15:15:33,437 WARNING MainThread PowerWall thread is dead.
2020-06-29 15:15:33,437 WARNING MainThread Attempting to restart thread PowerWall (thread has been restarted 0 times...
2020-06-29 15:15:33,440 INFO MainThread Creating EmonHubTeslaPowerWallInterfacer 'PowerWall'
2020-06-29 15:15:33,441 INFO MainThread Setting PowerWall name: powerwall
2020-06-29 15:15:33,442 INFO MainThread Setting PowerWall url: http://POWERWALL-IP/api/system_status/soe
2020-06-29 15:15:33,442 INFO MainThread Setting PowerWall readinterval: 10
2020-06-29 15:15:33,443 DEBUG MainThread Setting PowerWall pubchannels: ['ToEmonCMS']
2020-06-29 15:15:43,499 WARNING PowerWall PowerWall couldn't send to server: HTTPConnectionPool(host='powerwall-ip', port=80): Max retries exceeded with url: /api/system_status/soe (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x74b62350>: Failed to establish a new connection: [Errno -2] Name or service not known'))
2020-06-29 15:15:43,500 WARNING PowerWall Exception caught in PowerWall thread. Traceback (most recent call last):
return f(*args)
rxc = self.read()
I’ll keep you posted and will be asking for help without a doubt.
