I’m evaluating the buy of the Heat Pump Monitoring Bundle (emonHP) - 10 Kw with the aiming to implement the Level 3 (COP) RaspberryPi & MBUS based heat pump monitor** as per Heat Pump Monitoring - Guide | OpenEnergyMonitor.
My idea is to get the emonHP connected to the local network via ethernet cable.
It seems in the bundle there isn’t the outside temperature monitor. Am I right ?
If yes, is the DS18B20 temperature sensor right ? Anything else to connect it to the emonHP ?
Thanks a lot in advance for the help.
Cheers,
Alessandro
