Has anyone successfully managed to get feed data into a Homeassistant InfluxDB ? I’ve followed all the guides all I can say is the feeds are good, Homeassistant has the correct yaml entries, Influx is set up and HA connects to the DB fine, permissions are set on the db but still no data flows from the feeds. I’m wondering if there are undocumented set up steps.
If you are trying to log from the HA sensors that are created by the HA emoncms component, then I suggest asking on the HA Forum.
yep, already done that. Was hoping others on here have been this way
