I am running a local emoncms on RasperryPiB+ successfully since couple of month. Works excellent and fast.
Now I am running out of space on root. How can I increase the root partition? The card is 32GB and as far as Ican see only ~14GB is used. So how to get the extra 16G added to root?
Sorry, not quite understanding. I see /dev/root increasing, which is under
/dev/mmcblk0p2. So this partition should be increased. The /dev/mmcblk0p3 is behind and you say it is used for data? There is only 24M used.
I don’t think you will find this will change much - that is pretty much what it should be. The Install is optimised for emoncms, so root is relatively small and the bulk of space is left for data.
OK, my fault, have been searching now and found what is increasing my root space. I forget that motion is also running on this Pi. Works quite well but that is filling the root with mkv files. So I need to move the motion output to the remaining part of the sdcard. I am not an expert on Linux, but learning every day:-) So I need to create a partition with gparted or fdisk, mount it and then set the output of motion to go the new mount. Will that work with emoncms?
