Hi I have a number of Emonpi’s monitoring two buildings. The first two I set up and had an ethernet connection straight away provided, so they have been logging successfully and I am able to veiw the data remotely on emoncms.org. All good there. The other two Pi’s are in another building are logging ok and I have been dropping in to download the data. Today I finally got the network people to give me a connection which I test with them and it works, however, when I try and view the data via Emoncms.org I get innactive in all my feeds! I know the units worked as I set them up in my office pre instal on site and I could access them then. Any ideas, do I need to reset something?
It sounds like it’s just a connectivity issue from the new building. Looks like you need to revisit the Pi and check it’s still connected and can access the outside world.
