Im assuming emonTXShield project is archived and there are no kits
Possibly i am wrong which would be good, if not.
  1. Has anyone got them febricated in the UK.
  2. Has anyone got any surplus board.
Note: I can build from perfboard so not an issue and would redesign to work with ESP8266.
Welcome, Jeremy, to the OEM forum.
The only safe answer I can give you is email The Shop [email protected] for a definitive answer.
I would caution against using an ESPxxx for analogue to digital conversion, as far as I am aware, nobody corresponding on this forum has successfully used any ESP processor for energy measurements. If you want to use a dedicated analogue to digital converter for voltage and current measurements and save the ESP for the communications side, then others have been successful doing it this way. Equally, I don’t see a significant problem keeping the Arduino for measurements and replacing the RFM with an ESP for data transmission.
We do not have any stock of the kits left in the Shop. We have a couple of the thru-hole parts left, like the jack plug sockets, so if you need anything just email us.
Thanks for the confirmation. I’m using the uno+esp8266 option, ran into the only 1 a2d converter on esp8266. I have other projects with additional dedicated a2d’s for measuring temps so know it works (beer related). The kit was ideal, and low effort.
