Hi all,
I’ll soon be getting an Ideal Logic Air 10kW heat pump installed alongside a 250l cylinder with level 3 heat pump monitoring which i’ll be looking forwards to integrating in to HA.
It seems that Ideal heat pumps are pretty good however not particularly common, there are a few available on heatpumpmonitor. I don’t really see them discussed much at all…
We will be moving from a gravity fed vented cylinder to unvented. We currently have power shower (Triton TDPS1040) which I understand has a pump and would not be compatible with a vented as it’s designed to work at 1 bar. We don’t have any immediate plans to renovate the bathroom (although it needs it!) so I imagine we need to switch the Triton to a mixer shower and remove wiring. Are there any other gotchas to look our for when moving from gravity fed?
I appreciate showers and plumbing in general isn’t the key focus of this community but suspect a few of you would have been through a similar situation.
