How to set MQTT server / what are expected mqtt data?
The mqtt input for emoncms can be a great help if you specifically have mqtt data to log, but don’t be tempted to transition to mqtt from http just to make it mqtt, you can always make your input data available to mqtt services as well! you do not need to exclusively use one or the other. Comparisons pop up here on the forum quite frequently and whilst mqtt has it’s advantages, http is on the whole more reliable, accurate and robust where emoncms is concerned, depending on how it’s implemented of course, you can also have bad http as well as good mqtt.
See this discussion from just yesterday My Solar app calculation errors
