Hi, I wonder if anyone could advise what to do next, please?
I have an emonBase with emonpiRelease: emonSD-24Jul20 and 3 EmonTx’s
The relevant emonhub config section is below.
[[15]]
nodename = emontx3cm15
[[[rx]]]
names = MSG, Vrms, P1, P2, P3, P4, E1, E2, E3, E4, T1, T2, T3, pulse
datacodes = L,h,h,h,h,h,l,l,l,l,h,h,h,L
scales = 1,0.01,1,1,1,1,1,1,1,1,0.01,0.01,0.01,1
units = n,V,W,W,W,W,Wh,Wh,Wh,Wh,C,C,C,p
whitening = 1
[[16]]
nodename = emontx3cm16
[[[rx]]]
whitening = 1
[[17]]
nodename = emontx3cm17
[[[rx]]]
whitening = 1
When I set it up initially, all three nodes appeared on the input tab and were collecting data. Then after a day or two, two of the inputs stopped updating. I tried powering the EmonTx off and restarting the emonbase, but they wouldn’t update. The I tried deleting the three nodes (emontx3cm15,emontx3cm16,emontx3cm17) in the hope that restarting the Emonhub would simply start everything from scratch. Unfortunately they remain deleted and I’m not sure how to restore them.
I have no idea why the inputs stopped.
Everything seems to be running OK:
SERVICES
emonhub
Active Running
emoncms_mqtt
Active Running
feedwriter
Active Running - sleep 300s 0 feed points pending write
service-runner
Active Running
emonPiLCD
Failed Failed
redis-server
Active Running
mosquitto
Active Running
demandshaper
Active Running
Is there a simple way to restore the inputs or start from scratch?
Thanks!
