Hi folks. I’ve got my controller and module boards up and running on my home network. Now I need to change it to my campervan’s network.
The problem is I can’t work out how to change the wifi settings!
I tried reflashing the Wemos D1 Pro, but it just used the original wifi.
I tried shorting out the wifi reset pins, then plugging power back in the the short still in place. But when I power cycled it again it just went back to the original Wifi network.
I’m starting to feel silly, as I’m sure there should be an easy way to do this. Right now though I’d take any way of doing it!
Plugged in the micro USB pushed this button for a couple of seconds and then it went offline. Then the BMS CONTROLLER WiFi network showed up. Went to 192.168.4.1, filled in the new WiFi credentials and it went offline again. Signed into the new WiFi network and there it was.
