How to disable the WiFi on RPi 3B+?
It would appear that by default the emonSD-30Oct2018 sets up the RPi 3B+ WiFi as an access point. I am using Ethernet cable, so I want to disable the WiFi for security reasons.
Ref:
To completely disable the onboard WiFi from the firmware on the Pi3, add
dtoverlay=pi3-disable-wifi
in /boot/config.txt .
This is documented here. Please be sure to use an up to date firmware, this feature was added in January 2017.
There is also an overlay for disabling onboard bluetooth : pi3-disable-bt . If you want to disable both wifi and bluetooth, you need to add these 2 lines :
dtoverlay=pi3-disable-bt
