Hello @cidirome there’s no input process to support that at the moment. Perhaps the easiest way would be to put together a little script that polls emoncms or listens to the MQTT messages sent by emonhub…
What setup do you have there? is it an emonPi/base? standard emonSD configuration?
What I currently have is a cron running a shell script every 2 minutes querying some emonCMS feeds and doing some calculations to decide what to do, but I would like to step to the next stage and directly control the go-E wall box from emonCMS.
My config is a tweaked EmonPi with a custom firware that sends the values to an EmonCMS installed in my “router/linux server”.
The main issue is that it is not a very elegant way to do it.
I think that if I could integrate it in EmonCMS would be better and more responsive to realtime changes in values.
And integrating it would allow others to use a setup like this without messing with the command line.
