Any use as a visual?
Hot Water Cylinder Visualiser · dbuezas/lovelace-plotly-graph-card · Discussion #294
My version (isn’t quite right and only works in old Lovelace dashboards - I’ve stopped playing with it
type: custom:plotly-graph
fn1: |
$ex {
vars.title = 'Water Tank'
vars.mask_height = 175 // SVG
vars.tank_height = 170
// sensors from bottom to top
vars.sensor_names = [
'sensor.tank2_ds18b20_2_temperature',
'sensor.tank2_ds18b20_1_temperature',
'sensor.tank2_ds18b20_5_temperature',
'sensor.tank_ds18b20_7_temperature',
'sensor.tank_ds18b20_4_temperature',
'sensor.tank_ds18b20_1_temperature']
vars.sensor_heights = [
1,
66,
92,
113,
136,
145]
// temp of a virtual top temp sensor
vars.top_temp_factor = 1.0
// colorscale
vars.min_temp = 30
vars.mid_temp = 38
vars.max_temp = 55
fn2: |
$ex {
// linearly interpolate between sensors in steps of 1cm (not accurate)
interps = []
vars.sensor_values = vars.sensor_names.map(sensor=>isNaN(hass.states[sensor]?.state) ? sensor : Math.round(hass.states[sensor]?.state))
let Ts = vars.sensor_values.slice()
let Hs = vars.sensor_heights.slice()
Ts.push(vars.sensor_values[vars.sensor_values.length-1]*vars.top_temp_factor)
Hs.push(vars.tank_height)
for (let i = 0; i < Ts.length - 1; i++) {
for (let step = 0; step < Hs[i + 1] - Hs[i]; step++) {
let interp = Ts[i] + (step * (Ts[i + 1] - Ts[i])) / (Hs[i + 1] - Hs[i])
interps.push([interp,interp,interp]);
vars.z = interps;
vars.x = [10,20,70];
// array 0 - to height of tank (-1)
vars.y = Array.from(
{ length: Hs[Hs.length -1] },
(_, i) => i
).map(y=>y*vars.mask_height/vars.tank_height)
vars.tick_height = vars.sensor_heights.map(h=>15+h*vars.mask_height/vars.tank_height)
vars.tick_text = vars.sensor_values.map(v=>Math.round(v)+'°C')
entities:
- entity: ""
z: $ex vars.z
x: $ex vars.x
"y": $ex vars.y
type: heatmap
zmax: $ex vars.max_temp
zmid: $ex vars.mid_temp
zmin: $ex vars.min_temp
showscale: false
colorscale: RdBu
contours_coloring: heatmap
raw_plotly_config: true
refresh_interval: auto
ha_theme: true
config:
staticPlot: true
layout:
paper_bgcolor: rgba(0,0,0,0)
plot_bgcolor: rgba(0,0,0,0)
title: $ex vars.title
yaxis:
tickvals: $ex vars.tick_height
ticktext: $ex vars.tick_text
tickwidth: 0
tickfont:
color: white
showgrid: false
zeroline: false
showticklabels: true
showline: false
visible: true
position: 0.57
scaleanchor: x
scaleratio: 0.9
xaxis:
visible: false
margin:
t: 40
b: 20
shapes:
- type: path
path: >-
M0,185 V0 H105.09 V184.46 Z M52.71,171.43
C72.88,171.43,89.26,158.75,90.43,142.73 V28.37
C90.43,23.34,87.75,18.76,83.62,16.65 L81.97,15.8
C62.7,6.1,40.47,6.38,21.4,16.53 C17.41,18.71,14.86,23.22,14.86,28.13
V142.71 C16.03,158.73,32.55,171.41,52.71,171.41 Z
fillcolor: rgba(18, 18, 18, 1)
line: null
color: rgba(18, 18, 18,1)
