bekaheni
(Nick McLean)
#1
Hi All,
Is it posible to show your monthly historic KW usage?
Strugled to create it in the dashboard and the apps will only show you your current month then it starts over when the next month comes along.
Just after a graph that will show how much I consumed each month a jan to dec bar graph.
Nick
If you have a cumulative kWh energy feed like this:
you can display this as a daily/weekly/monthly bar graph by enabling ‘delta’ option and selecting ‘bars’ and ‘daily’
If you don’t have a kWh Feed you can use the power_to_kwh Emoncms Input process to convert Power data to kWh increment data.
