I’m trying to understand which are the data I must use to login into emoncms into a brand new emonpi. Can someone help me ? Is this written somewhere in the doc ?
Initial setup docs are here:
I read
You should now see the emoncms user login page. Register a new account and then continue to the next step
I see the login page but I’ve no idea how to “register a new account”. Can you help ?
I could not see any “Register new account” because I registered an account already and enable_multi_user
was set to false
emoncms/default-settings.php at master · emoncms/emoncms · GitHub
You use the Username and Password that you set when you registered this account. If you have forgotten, then it is a different (and more complicated) problem.
