How do i change the port a self hosted emoncms install runs on?
I think by default i have it running on port 80, but i need that free for Caddy
Okay so the way todo this
edit the file at
/etc/apache2/ports.conf
change the Listen 80 line to whatever port you want to switch to
Listen 80
then also edit the emoncms.conf file in
/etc/apache2/sites-enabled/
change the line below to the same port you are switching to
<VirtualHost *:80>
then sudo service apache2 restart
