Hello,
I have an emonpi running, I have some temperature sensors that I log.
I want to create some temperature accessories in homebridge that can fetch the data of the emonpi.
I see that I can fetch the feeds data with a simple url:
http://192.168.1.252/feed/fetch.json?ids=4,5
and the respond is:
24.4,
37.3
I found a homebridge plugin named " Homebridge Http Temperature Humidity Sensor" that need the http respond to be in the following format:
"temperature": 25.8,
"humidity": 38
Is there a way to manipulate the url or somehow the json output to make it as the requested format?
Best regards
