I’m running the emonpi SD card image on a Raspberry Pi 1 and B+
Ok, it’s a little outdated but its purpose it to collect som edata and push it to my local emoncms server.
Unfortunately emonhub is producing quit high CPU load.
With default setinngs is consumes 30% of CPU time.
After disabling all interfacers, emonhub uses still 25-30% CPU time.
Is this a typical value?
So, I went through the run loop of class EmonHub and identified self._setup.run() as the cause.
Is there a need to check for updated settings with this frequency?
I don’t think it is worth spending so much MIPS on it, even on a RPi 2/3.
Whilst I have never looked or tested the CPU load consumed by emonHub, I am aware the settings are being checked a lot more frequently than was originally set.
Somewhere along the way the min once per second throttling has been removed, you could try editing the “>0” to “>1” in this line in emonhub_setup.py.
Do you think this should be a change we should make to emonhub? I see no reason why the settings need to be checked more frequently than every few seconds. However, emonhub has been proven running stable long term on all models of RasPi hardware with no issues.
I would definitely like to see this changed I’ve just done some tests on a Raspberry Pi 3 with nothing else running (just out-of-the-box emonpi SD), this is the emonhub python process CPU usage:
< 0: 11.9% - 13.9% (i.e., current sources)
< 1: 3.0 - 4.0%
< 5: 0.7 - 1.7%
<10: 0.3 - 1.3%
so it does make a huge difference even on a ‘fast’ Pi. I’m a novice with emonhub so I don’t know why it needs to keep checking to see if the config file has changed at all? Don’t most daemons read their config files at load time, and then only reload with a SIGHUP or SIGUSR? or “/etc/init.d/emonhub reload” type command?
Minimising the CPU and memory load just means that the box can do more tasks without being overloaded, so it is always worth a bit of optimisation IMHO! (I plan on monitoring several hires networked security cameras as well as running emonhub, for example.)
He did indeed! the suggestion was basically try swapping the 0 for a 1, I hadn’t noticed I got the arrows around the other way.
Thanks for supplying some data on the various times. The original value (from the OEMgateway) was 1s, this worked well and is the intended setting, I do not recall at what point the 1 became a 0, but the original emonhub was corrected back to a 1 many months ago.
Many of the settings in emonhub.conf are runtime settings, they can be changed on the fly when emonhub is running, that is an intentional feature.
The reason I would want to avoid the time being extended to 5 or 10 secs is the delay after saving the conf file before the settings are picked up can cause additional confusion, especially when the applied settings only effect data or features on a slow update 10s til the edited file is read plus 10s or more til the next data packet into emonhub, plus travel time to emoncms and screen update time, it can be a long time before a recent change is seen, in which time another edit of the settings could be applied etc so keeping the responsiveness of the runtimesettings sharp is beneficial.
This has proven to be even more necessary when it is possible to edit the settings from multiple places eg via emoncms. (especially when done correctly using configobj rather than editing the text file directly).
I think a 70% reduction on the current consumption with no loss of responsiveness is fine, each further second saved beyond that has only a minor impact.
The way emonhub settings are intended to work is to use predominantly default settings and only the alterations and personalised settings (eg url and apikey) NEED to be defined, this combined with a vast number of redundant node definitions means there is a lot of unnecessary conf file entries being checked for differences on the emonpi.
There is also a settings file for the init.d daemon located at /etc/default/emonhub, but this is a different thing altogether.
I’ve submitted PR for a return to 1s with a note that it could be extended if processing power is scarce, it hasn’t been problematic thus far so there seems little point making too drastic a change.
Tested and merged, thanks. Would it be possible to run-run your CPU test @sheffieldnick with the updated applied (Setup > Update emonPi in local Emoncms).
Besides a simple timer to check for updates, I propose to make use of file system features instead or in addition.
What about monitoring the config-file’s “modified time”?
We could check it manually https://docs.python.org/3/library/os.path.html#os.path.getmtime
or make use of a lib e.g.
Agreed! I was just about to suggest the same thing - test the file modified timestamp on the config file and only load it if it has changed. Far more efficient.
I’ve run Setup → Update emonPi but it won’t overwrite my modified emonhub_setup.py file. How do I force it forget about my edit and give me your latest release?
Watching the files “modified time” and only running the check then is a good idea, I’m unsure how essential it is though.
I’m not against the idea, in fact I have just added it to my long emonhub “todo” list and linked this discussion.
I do not have the time look into it yet and I have concerns about making further alteration to a file that currently works well and has done so for a long time, just because I am currently fairly familiar with it and have several plans for improving and extending it’s feature set.
For example I would like to introduce another method of managing the settings via MQTT as part of a larger overhaul to make emonhub more geared up for use with smaller network packets to make gsm use more efficient and affordable. It would also mean that if emonCMS(.org) makes moves towards running a MQTT broker in place or as an alternative to http(s) for remote devices, as long as the remote device can publish data to emonCMS, it can also subscribe to emonCMS for configuration settings, as well as for control features without any complicated port forwarding or running a server on the remote.
Independently of the above I also made some progress some time ago with an emoncms “emonhub” module which would provide remote management of one or more emonHubs from one or more emonCMS servers, my implementation was different to the current implementation as it conversed directly with emonhub and emonhub then saved any configuration changes to the local conf file rather than needing access to the file directly…
Command line settings were also in the pipeline eg it is a little known fact that emonhub has provision to pause interfacers and/or delete and rebuild interfacers, this is currently managed by editing the config file but there is no reason an interfacer couldn’t be paused directly via the command line (or from within another script) eg when updating rfm2pi firmware automatically stop the rfm2pi interfacer only and continue to get data from other sources rather than stopping emonhub.
None of these things prevent the idea you suggest, I just do not see a huge amount of benefit in changing something that works for minimal gain and therefore cannot justify spending time on it right now, especially when there are other changes planned and there are some much higher priority things to tackle first.
But if you wish to continue I will happily review and at least provide feedback on any proposed changes. I do try to keep emonhub cross-platform, although a quick glance at the modules linked didn’t suggest an issue there, but prior to the “emonpi” variant emonhub ran perfectly on windows too, I have not tried this version though.
# Check settings only once per second (could be extended if processing power is scarce)
now = time.time()
if now - self._settings_update_timestamp < 1:
return
# Check if file has been modified since last parsed
try:
modified = os.path.getmtime(self._filename)
if modified == self._settings_modified_timestamp:
return
except IOError:
# Pass on any file errors to handlers below
pass
# Update timestamp
self._settings_update_timestamp = now
self._settings_modified_timestamp = modified
In my tests this reduces the CPU load from 3.0 - 4.0% (1 second reparse) to only 0.3 - 0.7% (1 second check file modified, reparse if changed).
Great, It would be good to know his thoughts and intention’s so we can pull in the same direction, is this a private project or a community collaboration?
