I recently had a Vaillant Aerotherm Plus 5KW installed in our home, and I’m interested in adding the Monitoring System. Despite having detailed instructions, I don’t feel confident in my ability to install this on my own. I’m seeking a professional with the necessary experience to integrate this into our existing system. Naturally, I’m prepared to compensate for this service. We are located in the High Wycombe area, northwest of London.
Hi Thomas,
Thanks for your interest. Our ASHP monitoring bundle is fully pre-provisioned, so no setup will be required. However, you will want to get a plumber to install the heat and electricity meter. Any plumber should be able to do this, it’s quite straightforward. If you drop us an email we can recommend some plumbers that we’ve worked with before in the London area. [email protected]
Let us know if you have any questions.
Hi Glyn,
Thank you for your help, email send.
Regarding the Monitoring System, is emonHP a recommended setup?
