I just acquired an emonbase and emontx3 and the first couple of days everything worked fine. Now, in the last few days, my kwh feed keeps resetting to zero as per below picture.
I have two feeds, one CT is measuring the house energy and the other is measuring my heating system. Both feeds reset at the same time and, sometimes, twice in the same day. During the times this happens, there’s nothing peculiar occurring like a power loss. In fact, the emonbase is being powered by an UPS. Both feeds are being stored locally.
Hi Dan, this thread is well over a year old, a lot can change in that time. Can you share more info on the issue you have.
Where do you see the issue? How often does it happen?
How is your input processing set up? What feed types are they?
What is your setup (emonPi/emonSd etc)? Is it up to date?
Is this a new issue or has it always misbehaved?
I second what @4est said. I have upgraded to the latest version and whenever I have a power outage, the feeds goes to zero! If any logs or other info is required, just let me know.
