Hello, I use emoncms since 4 years. Last year I backuped from the old Raspberry Pi 3 with username pi the complete database and restored the data successful in the new Raspberry Pi 4 with username iobroker.
I made a mistake and have to backup the data and restore it after new installation of the OS. While backup I received a failure in the text message box: Emoncms export completed with ERRORS.
I have to write the password in the terminal. How I can write the password?
I am ready with my new SSD and tried to restored the old data. Also here the text write the password. How I can write the password?
Export fail:
Import fail:
=== Emoncms import start ===
2024-03-03-18:44:42
Backup module version:
"version" : "2.3.3",
EUID: 1000
Reading /opt/emoncms/modules/backup/config.cfg....
Location of data databases: /var/opt/emoncms
Location of emonhub.conf: /etc/emonhub
Location of Emoncms: /var/www/emoncms
Backup destination: /var/opt/emoncms/backup
Backup source path: /var/opt/emoncms/backup/uploads
Starting import from /var/opt/emoncms/backup/uploads to /var/opt/emoncms/backup...
Image version: emonSD-10Nov22
new image
Backup found: /var/opt/emoncms/backup/uploads/emoncms-backup-Pi400-2024-03-03.tar.gz starting import..
Read MYSQL authentication details from settings.php
Decompressing backup..
sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
sudo: a password is required
mkdir: cannot create directory ‘/var/opt/emoncms/backup/import’: File exists
emoncms.sql
settings.ini
phpfina/
phpfina/369.meta
phpfina/373.meta
phpfina/356.meta
phpfina/203.dat
phpfina/335.dat
phpfina/291.dat
phpfina/230.dat
phpfina/178.dat
phpfina/352.meta
phpfina/143.dat
phpfina/357.dat
phpfina/168.meta
phpfina/370.dat
phpfina/335.meta
phpfina/364.meta
phpfina/156.dat
phpfina/171.meta
phpfina/244.dat
phpfina/232.dat
phpfina/363.dat
phpfina/140.meta
phpfina/258.meta
phpfina/186.meta
phpfina/236.dat
phpfina/355.dat
phpfina/241.dat
phpfina/245.dat
phpfina/227.meta
phpfina/269.meta
phpfina/272.dat
phpfina/293.dat
phpfina/176.meta
phpfina/166.dat
phpfina/253.dat
phpfina/137.dat
phpfina/380.meta
phpfina/262.meta
phpfina/231.dat
phpfina/270.dat
phpfina/274.dat
phpfina/240.dat
phpfina/255.dat
phpfina/385.dat
phpfina/350.meta
phpfina/367.dat
phpfina/125.dat
phpfina/265.meta
phpfina/264.dat
phpfina/184.meta
phpfina/195.meta
phpfina/125.meta
phpfina/386.dat
phpfina/195.dat
phpfina/267.meta
phpfina/366.dat
phpfina/360.meta
phpfina/263.dat
phpfina/250.meta
phpfina/249.dat
phpfina/383.meta
phpfina/228.meta
phpfina/241.meta
phpfina/256.meta
phpfina/239.meta
phpfina/246.dat
phpfina/242.meta
phpfina/235.meta
phpfina/151.meta
phpfina/298.meta
phpfina/240.meta
phpfina/196.meta
phpfina/198.meta
phpfina/138.meta
phpfina/259.meta
phpfina/257.meta
phpfina/171.dat
phpfina/340.dat
phpfina/254.dat
phpfina/261.dat
phpfina/376.meta
phpfina/367.meta
phpfina/151.dat
phpfina/268.dat
phpfina/197.meta
phpfina/186.dat
phpfina/272.meta
phpfina/363.meta
phpfina/236.meta
phpfina/253.meta
phpfina/350.dat
phpfina/196.dat
phpfina/366.meta
phpfina/362.dat
phpfina/141.meta
phpfina/129.dat
phpfina/147.meta
phpfina/344.dat
phpfina/120.meta
phpfina/170.dat
phpfina/197.dat
phpfina/185.dat
phpfina/368.meta
phpfina/184.dat
phpfina/382.meta
phpfina/144.meta
phpfina/294.meta
phpfina/230.meta
phpfina/234.dat
phpfina/365.dat
phpfina/386.meta
phpfina/140.dat
phpfina/258.dat
phpfina/129.meta
phpfina/255.meta
phpfina/227.dat
phpfina/154.meta
phpfina/293.meta
phpfina/371.dat
phpfina/370.meta
phpfina/375.meta
phpfina/339.dat
phpfina/376.dat
phpfina/120.dat
phpfina/380.dat
phpfina/252.dat
phpfina/342.meta
phpfina/338.meta
phpfina/379.meta
phpfina/389.dat
phpfina/344.meta
phpfina/176.dat
phpfina/185.meta
phpfina/259.dat
phpfina/237.dat
phpfina/147.dat
phpfina/260.dat
phpfina/355.meta
phpfina/267.dat
phpfina/144.dat
phpfina/137.meta
phpfina/297.dat
phpfina/175.meta
phpfina/178.meta
phpfina/372.meta
phpfina/231.meta
phpfina/247.dat
phpfina/365.meta
phpfina/343.meta
phpfina/256.dat
phpfina/361.meta
phpfina/362.meta
phpfina/358.meta
phpfina/341.meta
phpfina/246.meta
phpfina/371.meta
phpfina/243.dat
phpfina/238.meta
phpfina/243.meta
phpfina/167.meta
phpfina/292.meta
phpfina/275.meta
phpfina/206.dat
phpfina/247.meta
phpfina/145.dat
phpfina/275.dat
phpfina/152.dat
phpfina/233.dat
phpfina/180.dat
phpfina/203.meta
phpfina/265.dat
phpfina/153.dat
phpfina/242.dat
phpfina/168.dat
phpfina/340.meta
phpfina/254.meta
phpfina/232.meta
phpfina/382.dat
phpfina/368.dat
phpfina/357.meta
phpfina/388.meta
phpfina/297.meta
phpfina/249.meta
phpfina/250.dat
phpfina/337.meta
phpfina/379.dat
phpfina/356.dat
phpfina/179.meta
phpfina/290.meta
phpfina/154.dat
phpfina/233.meta
phpfina/337.dat
phpfina/383.dat
phpfina/336.dat
phpfina/229.meta
phpfina/359.meta
phpfina/155.dat
phpfina/358.dat
phpfina/262.dat
phpfina/206.meta
phpfina/375.dat
phpfina/234.meta
phpfina/298.dat
phpfina/161.meta
phpfina/170.meta
phpfina/299.meta
phpfina/248.meta
phpfina/266.dat
phpfina/207.dat
phpfina/207.meta
phpfina/369.dat
phpfina/138.dat
phpfina/181.meta
phpfina/385.meta
phpfina/139.dat
phpfina/268.meta
phpfina/235.dat
phpfina/251.dat
phpfina/198.dat
phpfina/389.meta
phpfina/145.meta
phpfina/342.dat
phpfina/343.dat
phpfina/252.meta
phpfina/166.meta
phpfina/360.dat
phpfina/239.dat
phpfina/167.dat
phpfina/261.meta
phpfina/143.meta
phpfina/364.dat
phpfina/388.dat
phpfina/181.dat
phpfina/361.dat
phpfina/292.dat
phpfina/294.dat
phpfina/179.dat
phpfina/339.meta
phpfina/152.meta
phpfina/351.meta
phpfina/248.dat
phpfina/266.meta
phpfina/161.dat
phpfina/229.dat
phpfina/244.meta
phpfina/336.meta
phpfina/372.dat
phpfina/351.dat
phpfina/156.meta
phpfina/139.meta
phpfina/359.dat
phpfina/341.dat
phpfina/352.dat
phpfina/263.meta
phpfina/257.dat
phpfina/291.meta
phpfina/180.meta
phpfina/155.meta
phpfina/141.dat
phpfina/124.meta
phpfina/237.meta
phpfina/270.meta
phpfina/274.meta
phpfina/260.meta
phpfina/338.dat
phpfina/269.dat
phpfina/228.dat
phpfina/153.meta
phpfina/373.dat
phpfina/238.dat
phpfina/124.dat
phpfina/299.dat
phpfina/245.meta
phpfina/290.dat
phpfina/175.dat
phpfina/251.meta
phpfina/264.meta
phpfiwa/
phptimeseries/
phptimeseries/feed_377.MYD
phptimeseries/feed_127.MYD
phptimeseries/feed_126.MYD
phptimeseries/feed_131.MYD
phptimeseries/feed_148.MYD
phptimeseries/feed_149.MYD
phptimeseries/feed_183.MYD
phptimeseries/feed_169.MYD
phptimeseries/feed_191.MYD
phptimeseries/feed_130.MYD
phptimeseries/feed_165.MYD
phptimeseries/feed_204.MYD
phptimeseries/feed_187.MYD
phptimeseries/feed_205.MYD
phptimeseries/feed_164.MYD
phptimeseries/feed_381.MYD
phptimeseries/feed_157.MYD
phptimeseries/feed_374.MYD
phptimeseries/feed_387.MYD
phptimeseries/feed_159.MYD
phptimeseries/feed_201.MYD
phptimeseries/feed_384.MYD
phptimeseries/feed_390.MYD
phptimeseries/feed_160.MYD
Removing compressed backup to save disk space..
Stopping services..
Emoncms MYSQL database import...
Import feed meta data..
Restore phpfina and phptimeseries data folders...
OK
Updating Emoncms Database..
Restarting feedwriter...
Restarting emoncms_mqtt...
2024-03-03-18:45:21
=== Emoncms import complete! ===
Also I tried before restore the note: Backup first. Also here came the message: password in termminal!
Please help me for this issue. THANKS
