HeatpumpMonitor.org: Findings
I’m currently working on writing up findings from HeatpumpMonitor.org as a structured piece.
Comments very welcome!
HeatpumpMonitor.org findings
Not quite happy with these last two pages yet:
  • The importance of commissioning - I’m going to rewrite this one with a bit more of an intro to the work analysing the Electrification of Heat data and hopefully some numbers on how many systems appear to have high weather comp etc. It would be nice to have some examples of before and after optimisation here as well.
  • Recommendations (needs more work).
Might it be useful to indicate the RH% outside during the test conditions for ‘Maximum output capacities under defrost conditions’?
Dry bulb -7, wetbulb -8. So a -7 with 86 % Rh I believe it to be with EN14825
Thanks @chrisg @Nando.Tolboom We dont have humidity data for all tests, but I will add it where it has been noted, good idea, it’s obviously a key factor
Hi @TrystanLea, I am concerned that you have used my system (Samsung 12kW NE Derbyshire) as an example of oversizing. My usage is so atypical that I don’t think that your method of calculating heat loss will be accurate. I only run the heat pump during Cosy cheap times, don’t heat 2 of the bedrooms and put up with the north facing kitchen cooling to 15C at times. This means that our pre - install quoted heat loss which assumed steady state conditions and room temperatures of 18C in all rooms apart from living room (21C) was always going to be more than our current one.
I think if we did run 24/7 at 18C then 8-9kW might be a more accurate heat loss at OAT - 3.7C.
Hi TrystanLea, Is it possible a relationship exists within the dataset linked to the design choice of UFH and low temperature operation? The sole adoption of UFH on a surface area heat transfer basis suggests it should achieve lower flow temperatures when compared to radiators (or a mix of radiators + UFH).
Hello @MikeJH no problem, I’ve removed the use of your system as an example and replaced it with one that I helped do the system design for.
There are some high performing under floor heating systems on there, I haven’t specifically done any comparative analysis on that, apart from noticing that the design flow temperatures on some of the under floor heating systems is amazingly low!
Hi Trystan, Here is some source information extracted from the CIBSE “The UFH design and installation Guide”. It shows the ability to generate a low temperature heating system design and improve efficiency for UFH systems. The CIBSE does not present below 30C (Mean Water Temperature). However, I have extrapolated down to 25C (MWT) in the chart.
On a separate point, If you could remove the requirement of a buffer vessel, then it would reduce the flow temperature by ~3-4C. Is this a possible recommendation in your article for simple heating designs involving UFH only.
Here is a better comparison of a typical radiator (K2 Type) versus UFH. It shows the inherent design benefits of UFH versus a typical radiator system in lowering the water temperature. I ran these numbers when my own installer recommended a mix of radiators and UFH. In my case, it was an extensive retro-fit and I had the benefit of going fully UFH (top and bottom floors). A mix of UFH and radiators would have defaulted to a much higher mean operating water temperature, since it defaults to the radiator MWT. It was not an important consideration or conversation topic for the installer, but it would affect my future running costs and performance. As shown in the chart. I predicted a MWT difference of 20C for the house heat loss of ~40 W/m2.
Hi Trystan, The chart makes clear the relationship between low flow temperature and higher SCOP. I used your dataset to try and draw some further insights on the likely performance of the various emitters (old Rads, new Rads, UFH) and high SCOP. I made a crude attempt to filter each emitter type within the Top SCOPs and made the following observations.
  1. The old radiator systems obtained a SCOP>4 for 17% of that datasets ( only 12 houses in my filter).The high performers all had a temperature of <37C.
  2. The UFH systems obtained a SCOP>4 for 40% of that dataset (only 15 houses in my filter). The high performers all had a temperature <35C.
  3. The new radiators obtained a SCOP> 4 for 32% of the dataset ( 44 houses in my filter). The high performers all had a temperature <36C.
    If my filtering is reasonable, then it appears old radiators alone would be less likely to achieve a SCOP>4.0. This may explain the dominance of new radiators and UFH in achieving high SCOP outcomes within the Top of the SCOPs.
I checked the same dataset for the percentage of emitter types with SCOPs>3.5.
Old Rads: 67%, new Rads: 84%, UFH: 79%.
@TrystanLea are you still adding to this work? I might have time now to do some analysis of my system from the EoH days, through to it’s current operation if it would be useful to include.
I’ve not made huge strides in performance 2.8 up to 3.2, but I can try and pull the details together.
Thanks @HydroSam yes and great! any further insights you would like to add to the page Analysis of Electrification of Heat trial data — OpenEnergyMonitor 0.0.1 documentation would be very welcome.
I did do some more analysis of the data recently, visually inspecting the data for all 165 vaillants on there and noting how many were affected by patterns of running up to high temperatures and cycling on room temp.
An associated point I would like to explore in more detail is that this pattern where the compressor is going at near maximum is often a much less efficient part of the Vaillant’s operating range (as @Zarch notes in his blog). E.g at 40rps (35C flow, 7C outside) it should be possible to get COP of 4.6 but then at 110-120 rps, it’s right down at 3.3! This could help explain the lower % carnot that a lot of the systems appear to have. I added a note on this to the % carnot page here as well % of ideal Carnot COP — OpenEnergyMonitor 0.0.1 documentation
Under Recommendations. It may be helpful to offer a recommendation on the importance of finding the cheapest electricity tariffs for your household. In my opinion, the standard electricity tariff dominates running costs for heat pumps in the UK energy market. Typically time a “time of use” tariff or a “heat pump” tariff could offer cheaper electricity compared with the standard price cap across all ASHPs, if suitable for your household and lifestyle. Thereby allowing higher water flow temperatures, or simply reducing the monthly utility bills.
UK consumer organisation “Which?” are sending the same message about the importance of choosing the right electricity tariff:
