HeatpumpMonitor.org, adding a system, New emoncms.org app selector
With the intention of making it easier to add systems to HeatpumpMonitor.org and continuing with the closer integration discussed here HeatpumpMonitor.org self hosted systems
This is now live:
It will also list MyHeatpump app’s listed in emoncms.org sub accounts associated with the master account.
I’ve disabled manual URL entry as the above also helps to ensure that valid URL’s are entered. That may be an issue in some use cases. I am open to making it an option to enter a manual URL if this is problematic.
I’ve added some rules to the form:
  • Metering option for brine pump only shows for ground and water source
  • Cylinder coil and volume on;y shows for Cylinders
  • Legionella protection only shows for cylinder with coil or hex
  • Where legionella protection is applicable, the form asks if the system uses an immersion heater, if an immersion heater is uses the form asks if this is included in the metering.
  • If metering has string class1 and class2, MID is automatically selected
  • There is now an option to specify if metering includes primary and secondary circulation pumps as separate items, with the secondary pump option only visible if hydraulic separation is installed.
  • There is a specific option to specify if a backup heater is installed and used, if this is ticked the metering includes backup heater option is shown.
There is also the option at the start to select between a ‘keep it simple’ version of the form and the full form. The keep it simple option is the required and basic fields only.
I’ve just been updating my details. For a GSHP we don’t use freeze protection like anti-freeze valves and glycol is only normally used in the brine loops (not internally), so can some thought be put behind this please?
Hey @MWPHS, Fixed, This option now hides for ground and water source.
Great work! I noticed a few other GSHP installations didn’t know what to do with this task box either! :slight_smile:
When I tried adding a new system I was only able to complete form if I selected a cylinder with coil or hex. All other DHW options wouldn’t save with an error that I needed to set legionella protection.
Same Here
Will try your work around
