The circulation pump in the 9kW Daikin is the same as the others in the range up to the 16kW.
It’s a monster, it really is.
See, I wouldn’t know that NIBEs have external pumps and I could have looked at that information and just think they hadn’t ticked the box.
I guess you would only know how much electricity is consumed by getting details of the pump used.
What I might do if the site was mine was have the default view as fully monitored MID systems where you know for a fact that they include everything and then have tick boxes as you do now for MID not fully monitored, non MID without known/suspected errors and then those systems with known errors.
Then it would be clear and visitors to the site would be presented with verified properly metered data by default and if they want to look at others then it is their choice.
Some of us are sad middle aged people who have gone through a lot to make their heat pumps work well.
It’s pathetic I know, but to realise now that a system I thought was just better than mine but actually isn’t doesn’t feel so good.
Heat pumps have a problem, they are too complicated with too many variables for many people.
To get one to work well is quite a task, and sad as it is, many of us judge our work and get satisfaction by comparing to others.
I have spoken to Trystan about this aspect, as great as public data is, it is not always that healthy but it is so hard to avoid getting sucked into trying to be better.
I’m sure I am not alone in this, the nature of optimising a heat pump makes it competitive to some extent.
