Heatpump Setup USB port changes
Hi there ,
  1. I have a sharky 775 heatmeter connected to one usb port of the pi - PL2303 IC based MBUS adaptor
  2. I have an SDM120 connected to another port of the Pi - FTDI based RS485 adaptor
ttyUSB0 and 1 get changed at times when I reboot … Is there some way to stop this happening.
Gopi
Yes, instead of /dev/ttyUSB0 use the full device ID e.g
/dev/serial/by-id/sb-FTDI_FT232R_USB_UART_A4007TEm-if00-port0
You can find this ID with the command ls /dev/serial/by-id -la
Thanks @glyn.hudson . Do I need to ensure the same configuration settings for the shop HP kit ?
I was helping a local installer put in a shop HP level 3 and had to do some plugging and unplugging the USB devices till I got it working . Just wondering in hindsight if this was the cause of that .
Gopi
No, the emonHP in the L3 HP Bundle will be fully pre-provisioned. No setup config should be needed. If something doest work please give us a call or drop us an email.
